Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Model #cre9600cce the broiler works but the bake cycle will not work...all of the burners work. Do I just change the heating element and if so how do I do that?
    Guru:
  • 462 Answers
Its an electric range, believe your lower element is either bad or wire to it burned off or the thermostat or control to it are bad.
FYI the Broil element is upper and lower element is bake. Just so we are on the same page. Sorry if you already knew this.
The most common thing is a bad lower element where food has "boiled oveer" and got on the lower element causing a cold/hot spot and thus burns it out prematurly.
Shut off breaker, no power to unit, remove lower element. Inspect wires in back of element if tight and connected, keep wire ends out and test for voltage (usually 220-240 VAC) on the wires. No voltage here then the problem is above at the thermostat or operation selector switch or wiring or a safety  control and may even be in the clock timmer. If you have power there all these items are ok and again go to the element power off. Remove 1 wire which one dosnt matter. test for continuity of the element. It will proably read HIGH or infinity. My guess is anything over 30 to 70 ohms the element is bad.. the part number used to be located someplace on the element. Keep it together and un bent as much as possible becaused you may have to use the measuremants to secure a part number of  a generic element.
Hope this helps. If so please grade me accordingly and good luck.
Posted on Mar 04, 2009
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Kenmore electric range oven baking element does not go on eveything else works
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Jan 30, 2014 | Kenmore Ovens
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't work. Maytag Performa Stove. Broiler and burners work.
sounds like your bake element is gone
but the model number would help a great deal
pul out the stove unplug it, take off the back, and inspect the connections on the bottom element
if its gas its probably your ignitor
take out the racks
take out the bottom
set to bake
you should see a very bright light within a minute
if you dont thats the ignitor
anyway both parts are available
and both are a pretty starigt forward repair
Oct 09, 2009 | Maytag Performa PAV2200
My stove will not heat using bake but will work for broiler so I know it is not a heating problem. Help!
this model is not a dual fuel, and you do have a heating problem, there are two burners, a bake burner and a broil burner, both have ignitors. You have a bad bake ignitor.
Sep 27, 2009 | Maytag MGR5775QDS Dual Fuel (Electric and...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag dual oven upper oven not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerryrigging a bridge to wire the BAKE igniter to the BROILER controls.(Push/click plugs accessible by opening up the stove back) Testing thebroiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.)The parts and wiring are pretty simple and visual once you get thecovers off. Opening up the stove back is just a matter of removingseveral screws. UNPLUG the stove before you work. If you test as Idescribed, make all connections while UNPLUGGED and then plug it inonly for the brief test. Unplug again while disconnecting/reconnecting.Hope this helps.
Nov 25, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
349 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
