Question about Curtis-Mathis CM19011 TV
Tv display says heat run
Curtis mathes tv model # cm19102
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
Can i reset the parental control on a curtis mathis 19 inch model number ledvd1975
Download its user manual. It will have all the details. Click here to download it.
Apr 22, 2012 | Curtis CM19102 19" TV
I have a Curtis Mathes 19" Color TV Model CM19102 and the worg "Line" appears in upper right corner of screen and I cant change it.Thanks.HR Rose
Hello
There are two resons for this fault. The first one is with less heght or vertical lenearity adjustment. The second one is with due to weak electrolytic capacitors in vertical output section on the circuit board. In most cases, replacing all the electrolytic capacitors [four or five of them will be there]; will rectify this problem. The line you see on the upper part of the screen is techniclally called as vertcial retrace line. The main cuse of this will be due to weak capacitors on the circuit of that section itself. OK.
Nov 24, 2011 | Televison & Video
Cannot get remote control to work on brand new Curtis LED 1930A
I need 5 digit code that will work on comcast remote for Curtis LED 1930A
The code in sistruction book is 007F
and it will not work !
Sep 03, 2011 | Curtis CM19102 19" TV
Need manual for model number cm19102 serial number mt14cb0349 made in april 2001 its a curtis mathis tv
Hi oib,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
You can download a free copy here. www.manualsonline.com .
Thanks for choosing FixYa. Happy Holidays......John
Dec 29, 2010 | Curtis-Mathis CM19011 TV
Nedd to reset TV manually...... remote is not working
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
Jul 17, 2010 | Curtis-Mathis CM27101S TV
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
May 09, 2009 | Curtis-Mathis CM25011 25" TV
Curtis-Mathis CM19011 TV Logo
69 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
