Question about NetGear MR814 Wireless Router
Netgear MR814 won;t connect
I have wireless MR814 router and it was working fine till today morning. I can see all lights blinking etc ..ipconfig also gives me an ip address . My config is Cable Modem --> Router --> laptops . I tried wired/wireless connecting thru router, it does not work and I am not able to go internet. If I plug cable modem wire directly to my laptop, i can work. pls advice.
  • 611 Answers
Wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Posted on Mar 04, 2009
My wifi light won't turn on and i have no wireless connection
you need to configure the wireless settings
connect to your router using a cable and then go to your browser to
go to wireless and setup your wireless network settings
Feb 26, 2012 | NetGear MR814 Wireless Router
NetGear wireless router: my laptop won't connect after hibernate
go to a command prompt window (start, type in "cmd") once there type "ipconfig /release" (space between ipconfig and the /)
wait for it to release, then type "ipconfig /renew" (all without the quotation marks) this should work
Feb 23, 2010 | NetGear WGT624 Wireless Router
My wired connection to the router works fine but the wireless connection is not working
What have you tried?
Is this a new router? (Some Netgear have wifi turned off by default)
do you see the SSID name on your computer?
Has it ever worked?
It does happen that the output transistors fry so it works wired but not wireless
Oct 10, 2009 | NetGear MR814 Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Connecting XP wireles Client to Netgear MR814 v2
Please see if this things are done:
  1. Power on your wireless device - now a days, laptop have a manual switch aside from software-base application. It usaully a tiny switch witch is mostly located at the edge of your laptop.
  2. You might have entered an invalid key - use notepad to enter your security keys then cut and paste it on your application setup.
  3. Reinstallation of your device driver.
  4. Your router networking is not broadcast so do it manually by supplying SSID and security keys on the setup menu.
If this thing are done correctly, better see your supplier.
If you think this things are helpful, please rate me.
Mar 27, 2009 | NetGear MR814 Wireless Router
Need to get my netgear wireless router mr814 to install
Please view my How-To on configuring the Netgear MR814 router. I would be happy to answer any specific questions you may have.
Good Luck,
Mar 06, 2009 | NetGear MR814 Wireless Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
In your setup click the 'Erase' button, this will reset it to factory settings.
If you forgot the password or IP and can't do this, there is a reset button on the back of the unit. Hold it in for about 10 seconds until the power light blinks on. Then release the button and allow the router to reboot. This information is in your manual. If you've lost your manual, click here.
Feb 26, 2008 | NetGear MR814 Wireless Router
I lost my CD
You can reset your Netgear router/wireless MR814 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless MR814 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at to fix Netgear router/wireless router issues.
Oct 17, 2007 | NetGear MR814 Wireless Router
NetGear MR814 Wireless Router Logo
216 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
