To reset the Blackberry Bold 9000 / 9700 with three methods. In the first method you hold down the Alt key, the Caps lock key and hit Delete. Your Blackberry will start resetting. This process will take about 2 minutes to complete. The second method is the double reset. Hold down the Alt key, the Caps lock key and hit Delete twice. This method is helpful if your Blackberry is frozen. The third method is called the battery pull method. Remove the battery and keep it out for about 30 seconds and then put it back and power on. It will reset in 2 to 3 minutes. You resort to this method if the first two methods don't work.
If your BlackBerry Bold 9000 series device is frozen or not responding, you will probably want to reset the unit. Here are the different types of resets that can be perfomed in the order they should be tried. Soft Reset PressALT + RIGHT SHIFT(CAP) + DELETE. Double-Soft Reset PressALT + RIGHT SHIFT(CAP) + DELETE. The screen will go blank for a few seconds. When the screen comes back on, immediately pressALT + RIGHT SHIFT(CAP) + DELETEagain. Hard Reset If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
Take the battery out and start the blackberry desktop manager. The blackberry can be restored in this condition. Just search for restoring bb to factory settings on the web. Here is an Blackberry Repair Guide that shows how to open a Blackberry. If you want somebody else to do it for you go to Blackberry Repair.
is very simple upgrade the software then plug your blackberry with your computer delete your old software from your blackberry and install the new one now works better and faster
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
