Question about JVC HD-61G787 61" Television
Cant program digital channels.
When I try to program the digital channels the tv does nothing. It used to bring up a screen saying how many channels have been found and it does not come up now. What can I do?
    An expert whose answer gotĀ voted for 100 times.
  • 105 Answers
Nothing. Digital Tuners Broke. I wouldn't be suprised if your TV freezes up momentarily (or for a long time) when you switch over to the Digital Channels.
This TV has 1 tuner for analog channels and 1 tuner for digital channels. You can probably find the Digital Tuner on Ebay and replace it.
Posted on May 18, 2009
How to get digital channels, nothing on tv screen and will not pick up channels
Do you have an antenna attached?
Have you selected Antenna/Tuner for the input source?
Have you tried to use the Auto-Program feature to detect the active channels in your area?
Mar 07, 2015 | Televison & Video
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
Flat screen tv,,,,trying to hook up the directv...when i turn tv on, it says no signal. not sure why i cant chng channel?
there is nothing programmed in, you must do this first. Also have a good tuner or direct tv operates off of different channels it must be hooked up and on first and then programmed if you are trying that way, or use input jacks or HDMI if capable
Jan 02, 2011 | Polaroid Televison & Video
I cannot briing in a picture. Upper left corner of picture says it is on channel 4...upper right corner "no programs availab le"How do I program TV to bring in a picture.; I am on Insight Cable.
Typically the cable box is the source of your channel programming. If you're getting the "no programs available" you need to find if that notice is from your TV or your cable box. Check the connections from your cable source to the cable box and from the cable box to your TV.
Make sure that your TV is set on the proper source selection. Most Projection TV's have several (ant, cable A, B, DVD etc) check your on-screen menu for which one and make sure the cable is connected to the proper input ports on the back of your TV.
If you disconnect the cable between the tv and cable box and still get the "no programs "...then it's your TV.. but if you lose that warning, then it's coming from the cable box... If after checking your connections, disconnect the power to your cable box and let it sit for 5 minutes and then reinsert the power to the box and see if you get a reset with signal...... If nothing after all this, contact your cable provider to check their signal to your house and also the cable box.... Hope you have quick success on this!
Dec 17, 2009 | Televison & Video
Cant get any channels between 34-98
If your remote does not have a menue to access auto channel programing, look for it on the TV itself. It may be hiding behind a small panel door, usually toward the bottom of the tv.Once you find it you may have to figure out how to bring the screen up that has programing feature. The screens usually can be brought up by channel or volume controls. Once the auto programing feature appears you push or press ok. If that does not work you should be able to manually key in each channel, one at a time. There as many variations as tvs. Hope this helps. Good luck. Larry
Aug 25, 2009 | GE 19GT317 19" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Cant get channels to program manual or auto
Try the STANDAR mode search, instead of AUTO mode, also try IRC mode, and HDR more, maybe thats why you dont get any channel...
Mar 19, 2009 | Olevia 227-S11 27 in. LCD TV
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
JVC HD-61G787 61" Television Logo
485 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
