Water inlet solenoid open and shuts continuously (slowly) until it stops.
    Scholar:
  • 106 Answers
Check the connections to the solenoid, tight? If problem persists change the solenoid, easily done.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 04, 2009
My mom's jenn air side by side refrigerator randomly started dispensing water out of the front. I couldn't stop it until I opened the door. now nothing works on the dispenser but the light.
Sounds like a faulty inlet water solenoid valve. This is normally located on the back of the refrigerator and the water supply from your home connects to it. Be sure to shut off water supply to the solenoid valve before you remove it.
Feb 05, 2015 | Jenn-Air Refrigerators
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Machine fills too slowly and continues to fill in whole cycle
Remove the water filler hoses at the machine and test the flow of each one. If very slow, check the inlet screens on the faucet ends for plugging and make sure the faucets furnish full flow. The hoses themselves can sometimes become restricting of flow--replace them if so. Next, check the inlet solenoids on the machine for proper flow and shutoff when the power to them is stopped. They may or may not be cleanable--replace them if they are trouble. Hope this helps!
Jan 10, 2010 | Admiral AW22 Top Load Washer
Water drips into the "tub" when unit is shut off. It stops when I shut off the hot water supply line. When I try to wash with just the cold water line open and on the cold water setting, it give me a HF...
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the openings on the valve. Make sure they are clear or rust or debris. Check the solenoids for continuity using a multimeter or ohmmeter. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water stopped coming into machine. cleaned the screen and still would not work. switched hot and cold hoses and set temp. on hot. worked for one load, but now the water will only stay on for about 10...
Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Test for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helped and best wishes.
Aug 30, 2009 | Maytag Legacy Series Top Load Washer
Washer shuts off. We start it, it shuts off. We start it again, shuts back off. Sometimes it runs, sometimes it doesn't.
Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 14, 2009 | Washing Machines
My series 80 top load washing machine is filling very slowly in cold water settings
Check the cold water supply at the water inlet valve. Remove the supply hose and check that the small screen in the inlet valve is not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 08, 2009 | Washing Machines
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Cold stopped working
Check the strainer in the cold water inlet line. Make sure it is not plugged. Then,put the cold water line into a bucket and open the valve slowly until water comes out. If water flows freely, it's probably the cold water solenoid. It's pretty easy to replace.
If not, check all valves upstream, check for a collapsed hose, or mineral build up in the pipe (galvanized pipe)
Mar 04, 2008 | GE DBSR453EBWW Electric Dryer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
