Question about Enlight 17IN LCD PC SILVER/CHARCOAL W/ 200W INTEL 845GVSRL M/B KYBRD/MOUSE (ENLP771S01845R) Barebone
Intel 845gvsr problem of thermal heating of cpu
I m facing problem with 2.4ghz and intel 845gvsr problem,
when i start my pc after sometime it automatically shutsdown
after few minute when i re boot i get a message unxpected shutdown due to thermal heating of cpu, where as the cpu heatsink fan is quite cool, it gives a alarm sound of cpu heating, i tried with other heatsinks the result is same, where does my problem lies in cpu or motherboard.
  • Yo Mu Mar 31, 2009
    i've intel 845GVSR board with 2.4GHz processor with 1MB cache. I am facing the same problem and for that i've replaced its FAN, applied heat sink paste beneth CPU fan, cleaned all possible dust, and inserted 2 fans in the cabinet (one for inward air in front and one for outward air at the back) but still its turn off due to thermal heat. what to do?
To solve the thermal heat problem
1. Apply heat paste pound inbetween the processor and motherboard.
2. Check the MotherBoard cpu pins are correct temper.
3. Check the CPU Fan's RPM in hardware monitoring menu in BIOS mode.
4. If dust is form inside of the fan rotar open the plastic lock and take the Fan out and clean clearly apply the oil slightly in the pully.
5. If This problem is till continue, Change the SMPS and rescet the BIOS setup. Now problem will clear.
6. Problem is till continue check the CPU and and then MotherBoard.
7. This is usefull to you. i think so. any how feadback to 'abdulsoftdrive@gmail.com'
THANKYOU
Posted on Mar 24, 2009
    Sergeant:
    Champion:
  • 271 Answers
.this a problem with the dust colection in the heatsink,but can also be the processor,,i think it's the motherboard.
Please don't forget to rate me "FIXYA"...thank you!
Posted on Mar 04, 2009
2 Suggested Answers
SOURCE: intel 845gvsr shutdown problem.
pls check your hard drive jumper settings
Posted on Mar 15, 2007
Display problem with Intel 845GVSR MB : My computer running on Intel 845GVSR MB with Intel Pentium 4 processor with 2.4Ghz and 768 MB RAM. When I start my computer no display appears. This used to...
was your mother board a brand new or just an old savge MB. try to check the DIMMS. Intel board was so sensetive in memory cards , they dont make a display as soon as your DIMMS are defective
Mar 27, 2017 | Intel Motherboard
I have intel 845GVSR motherboard for P4 CPU and i am unable to install audio driver from Intel CD ROM So how to find & install audio driver?
Check your "BIOS" to see whether the audio device is enabled!!
For the Intel Mobo 845GVSR is a discontinued product by INTEL, and also check your CMOS CR2032 3V battery if it need to be replaced.
If you have the MOBO CD all the drivers are there but maybe the drivers are outdated.
Aug 12, 2010 | Computers & Internet
Intel 845GVSR motherboard, No display.
onboard video chip is known to be faulty 90% of the time, get an add-in card replacement: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161011
Jul 03, 2009 | Intel Motherboard
Compatible processor 3.0 HT with 845gvsr board
if the processor you have is a pin type one or rather socket 478, yes it will be o.k
Jan 21, 2009 | Intel Motherboard
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
PC Freezing !
Update BIOS to P25 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=948&DwnldID=10130&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
Server starts to boot then powers off.
Check your CPU cooler. If it is not properly mounted your CPU/s could be overheating. There is a safety mechanism in Pentium chips that shut down the processor when it reaches a certain temperature. If your heat sinks are mounted correctly, check your Heat sink fans. Ball bearing fans are notorious for making a little noise then quitting.
Jun 10, 2008 | Intel Server Board SE7505VB2 Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
No display
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
60
Jan 15, 2008 | Intel Motherboard
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Enlight 17IN LCD PC SILVER/CHARCOAL W/ 200W INTEL 845GVSRL M/B KYBRD/MOUSE (ENLP771S01845R) Barebone Logo
747 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Larry Maranto
Jerry Umali
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
