Question about GE Washing Machines
We have a ge spacemaker washer & dryer unit, it seems that the tub is loosen.
  • 686 Answers
The entire tub unit should be able to bounce around in the cabinet. If you have ever heard a wash machine that went off balance the sound you hear is the tub pounding on the inside of the cabinet. If you don't have a leak you should be fine.
Posted on Mar 04, 2009
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
My GE Spacemaker dryer will run but the washer will not start in any cycle (stacked unit)
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
Mar 13, 2014 | GE Spacemaker Washer and Dryer Electric...
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Ge stackable wsm2700DAWWW makes noise and not drying properly.
GE HAS A REARBEARING THAT GOES OUT OVER TIME .. NORMAL WEAR AND TEAR FROM USE COULD ALSO BE YOUR HEATING PROBLEM IF THIS IS ELECTRICAL DRYER TUB COULD BE GROUNDING ELEMENT
Jan 24, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
New washer draining out while washing or rinshing
If this is a brand new unit, make sure that the drain hose is hooked up at a level at or above the level of the tub. If it is too low, it can siphon the tub of water.
Apr 30, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
RE GE spacemaker Mfg ID 3394721, SN CF2817278. How do I remove the 3 support suspension absorbers (also must remove tub) Is there any schmetic diagrams or drawings to explain the removal/replacement of...
big job.remove front panel.disconnect all hoses and wires,two bolts bottom l/r corners will allow you to slide whole unit out of cabinet.disconnect motor,transmission and tub.you will probably need suspension plate where shocks attach .holes are probably reamed out.$$$Hope this helps. please rate my response :)
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Leaking water while agitating
it sounds like a bad bearing... the tub is leaking it may leak into the bearing and cause your transmission to lose oil and water ...
Nov 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Burning belts
try taking a flashlight and looking very closely at the holes in the tub with a flashgoht to see if a foreign object such as a nail or screw has fallen through one of the holes in the tub and jamming it try to rotate the tub by hand and let me know
Jan 19, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Washing Machines Logo
83 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
