Question about Microsoft Office Professional 2007 Full Version for PC
Microsoft office '07 'error 25004 per-user install not supported'
I cannot reinstall my legit office '07 pro. I uninstalled it because I was having issues with my Outlook that I could not fix and I decided I wanted to start over. When I reinstalled in the first time it went back to the exact way it had been before the uninstall with the same problem, all my folders the same, etc. So I tried it again? This time, when I tried to reinstall it, halfway through it gave me that message above 'error 25004 per-user install not supported'. I am extremely frustrated. I do not have any program in the Suite installed and working. HELP! Thx, JW
  • Anonymous Apr 02, 2009
    i have the same problem what the hell I wont restore my laptop for this error.
Excel and ms office file are not open kindly give the solution.
Posted on Jun 15, 2009
Do a system restore. Worked for me I removed Office using Office2K7DelReg. Got the same error.
Accessories -> System Tools -> System restore,
Hope there is a restore point there.
Posted on Mar 12, 2009
Error 25004.config.xml not specified; A valid config.xml file must be authored when deploying '(null)'. i am installing microsoft office enterprise 2007 and i enounter this problem..how will i
If the version of windows installed on your computer is not activated you would face issues to use any applications once the product is expired.
But if you have an issue with office programs with an error 25004 on an activated version of windows
Then the reason might be corrupted installation of office 2007 on the computer.
Uninstall office 2007 manually from the computer then
re-install it and check if it helps.
Apr 25, 2012 | Microsoft Office Professional 2007 Full...
Problem installing office 2007.
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in or Microsoft Save as PDF or XPS installed, this may be the culprit. In both cases, by performing an uninstall on this add-in via the Control Panel, and then installing Expression Web, everything works okay. You can even re-install the Office 2007 add-in when you're done.
Goodluck,
Please don't forget to rate the solution
May 06, 2008 | Microsoft Office Professional 2007 Full...
I need to get my micrsoft office 2007 student back. I downloaded it but got a virus on computer now what to do? i stil have the product key!
Uninstall any AV from your computer. Install Avira AV (www.free-av.com). Run a complete scan so you can remove the virus (depending on which one, could be harder than others). if you cant remove the virus or if you do remove it but the Windows is corrupt, you will need to reinstall Windows and then reinstall you have to reinstall Office, with the same product key. I think you can activate your copy up to 3 times. If you can't, call Microsoft and tell them what happen. They WILL activate the copy for you.
I hope this helps. Please rate and provide positive feedback for our fast/free support today. Thank you :D
May 06, 2010 | Microsoft Office Professional 2007 Full...
When trying to install MS Office 2007 the installation interupts and it gives an error numbered 25004 , per -user install not supported . how can i fix this problem?
this is exactly as it sounds...you need admin rights and choose all users when it shows you to choose whom to have access to this program ...this being a Microsoft program ..do not supports limited access ...and need an administrator account to be installed and the access to all users...no mater of type..
Jan 14, 2010 | Microsoft Office Project Professional 2007...
Error 25004.config.xml when installing MS Project 2007
Please follow the instructions in this article and see if you can uninstall MS Office 2007. After you completely uninstalled Office 2007, you can reinstall it if you wish.
http://support.microsoft.com/kb/928218/en-us
Oct 28, 2009 | Microsoft Office Project Professional 2007...
Microsoft Office Home 2007 error during setup. Error 25004.
Try YourUninstaller 2008, 1-Click Cleaner (Your uninstaller 2008) or TuneUp Utilities 2008/2009.
Try to delete every part of the office from your PC. Files in Document and Settings/User
Dig a little bit in your PC. In Windows folder, Program Files, Doc & Settings.....
That should be a sollution for your problem.
Jun 02, 2009 | Microsoft Office Professional 2007 Full...
Office 07 won't work on Vista
been there, have you tried getting it out from safe mode, if that dosen't work there is a utility called unlocker, here
http://ccollomb.free.fr/unlocker/
Iuse it when things like that happen, it will unlock it. But try safe mode first
Dec 21, 2008 | Microsoft Office Professional 2007 Full...
My Office 07 will not open, so I was going to try to uninstall it and reinstall it, but when I go into Control Panel to uninstall Office 07 a window pops up saying, "This product installation has been...
Try renaming the install directory. Normal install is located C:\Program Files\Microsoft Office\Office12. Rename office12 to office12bak (just in case you need to put it back again). This will normally allow you to reinstall office again.
go to website www.martau.com download uninstaller and completely remove previous version office. Using this application every entry related to previous version will be removed
Dec 18, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
3,373 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
