Question about Acer AL1511 15" LCD Monitor
I cannot adjust the screen resolution it says the monitor is default monitor.I restarted the computer and everything was big . now i have made it smaller by adjusting the mode thing to 800x600.now the colour is all broken up.
    Problem Solver:
  • 6 Answers
Sounds like a video driver problem. Download and install the latest drivers for your video card.
Posted on Mar 04, 2009
I just installed win7 and all mi icons are big, everything is big, please help me.
Right click on the desktop and go to personalize. Down in the bottom left corner click Display. Choose smaller 100%. If this is already checked, Right click on the desktop and click screen resolution. Pick a higher resolution and click apply. The higher the number the smaller everything will get, For Example. 1280x 720 is much smaller than 800 x 600
Mar 12, 2011 | AOC LM560 15" LCD Monitor
OUT OF RANGE: this words appear on my monitor, and it does not change. the monitor is black always.
The resolution your pc is set for is not compatible with the monitor.
To fix this, you need to start the pc in VGA mode. (640 x 480 lines) Start the computer and begin tapping the F8 key about once a second till you see a text screen with options displayed.
If you recieve a stuck key error, clear it (read the message) and continue to tap F8.
Choose the option to boot in VGA mode. When pc starts everything will look very big, like you're zoomed in.
Now you can change the screen resolution. Right click on background and choose properties, or display options, (depends on your operating system) find the option for resolution and change it to 800 x 600. (The screen will not change then and ther) Apply or OK the screen then restart the pc normally. Now you should be able to see more of the screen.
Go back to the resolution settings, and adjust it to your likeing and the limit of the monitor. Now it will apply immediatly, - click the save option that pops up with the change to lock in. If screen becomes unreadable, just wait 15 seconds and it will change back.
Dec 02, 2010 | BenQ Computers & Internet
My screen says auto configure when on Please Help pschubert61@hotmail.com
It's perfectly "normal" -- your LCD monitor is adjusting itself, automatically, to the output from your computer's video-card
(e.g., 800 by 600 by 60 Hertz).
Restart your computer in "Safe Mode", and reset the display-resolution to 800 by 600 by 60 Hertz. Then, restart,
and then everything will be OK. When it is, try to increase the resolution, incrementally.
Aug 30, 2010 | Acer 22" X223w LCD Monitor
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
Screen resolution
You will need to load the Video card driver for Vista for the model card you have in the system. Once this is done, you will be able to adjust the resolution.
If you need assistance in finding the video driver, post the details of the make and model video card in the system.
Mar 01, 2009 | 3M Vikuiti eXtended Resolution Video...
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Aug 19, 2008 | Princeton Digital VL173 Monitor
Acer AL1511 15" LCD Monitor Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
