Question about Sharp NAVITAR 1.2 INCH BUHL LCD LENS, WIDE-ANGLE, Projector Lamp FOR PROJECTORS => Model 825MCL01
How do I make my projector image square??
I have projectors in several different training rooms. Some of them project a perfect square and some do not. I've played with the keystone, aspect, etc. and still haven't been able to figure it out. Any ideas?
  • 2,236 Answers
Start with resetting to factory settings, then adjust keystone as necessary.
Posted on Jul 08, 2009
    Champion:
  • 205 Answers
Force the pc's into the native resolution of the projector. 1 to 1 mapping. Eliminates the scaling engine of the projector. good luck
Posted on Jul 07, 2009
  • 161 Answers
Is the projector in the center , how is the angle
Posted on May 09, 2009
    Problem Solver:
  • 6 Answers
This is due fixing problem, Your not fixied the projector properly. So just check whether pojector lens and screen center point both are same line. If not please correct it.
Regards,
prakasam
  • 22 Answers
They should all project OK it might be your graphics cards and wrong resolution that are to blame.
Marc Engineer
Posted on Jun 17, 2009
Projector screen size
It is usually based on the room you are installing the system in. What is the maximum distance the front of the projector can be from where the screen will be? With that answer, go to the projector mfr's website to see ow big that model will throw the image.
Aug 17, 2014 | Dream Vision CINEXONE, SL705X Projector...
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Failure to get a trully blank or black screen
Have never worked on a panasonic projector before I admit, but you get that effect when the 3 LCD panels inside a Sharp (and I assume all brands) LCD are misalligned. To get total black (LCD Projectors find this rather difficult due to the technology) the red , blue and green lcd pixels must be precisely allignend ( they are adjustable by technician and it's a fiddly job) I reckon the green panel is a touch out and it's peeking out between the red and blue squares.
Dec 12, 2009 | Panasonic ET LA780 Projector Lamp for 780...
Epson Powerlite 710 viewing issue
the fn + f8 should tally between the 2 or 3 different connections for it
Jul 20, 2009 | Epson ELPLP10S Projector Lamp for...
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
How do I make my projector image "square"?
i Believe you need to go into the projectors settings and adjust what is called the keystone, this changes the tilt effect that the projector throws, just keep messing with that setting until you get it how you like it.
Mar 05, 2009 | Sharp NAVITAR 1.2 INCH BUHL LCD LENS,...
Image problem
IF I understand the problem from the limited info in your question, the problem is a distorted picture on whatever surface [probably a wall, or screen] onto which the image is projected.
With all lenses, the axis [centerline of the lens projected] MUST be absolutely PERPENDICULAR [in both the vertical and horizontal planes] to the perfectly plane [flat] surface onto which the image is projected.
IF for example, the projector is mounted in a rear corner of the room, and the camera is aimed downward and to one side to project the image on the center of the opposite wall, or a screen located there, the image will be distorted. It will be larger on one edge [fartherist from the lens] and smaller on the opposite [nearest] edge.
If it is non-perpendicular in only one axis, then two opposite edges will be different lengths, and if out of perpendicular in two axis then no edges will be the same length.
The solution to this problem is that the center axis of the lens must be perpendicular to the surface projected on, in both vertical and horizontal axis.
Feb 14, 2009 | Sharp BQC-XGE630U/1 Projector Lamp for...
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
1,219 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
