Question about Samsung Cell Phones
Tried to pair jawbone with samsung insinct but will not pick up jawbone
Dont have the manual to pair jawbone to samsung phone
Posted on May 17, 2009
How do I pair Jawbone headset to Samsung Galaxy S phone
Follow these steps to pair your iOS device:
  1. Turn Bluetooth on (from the Bluetooth menu on your iOS device)
  2. Put your Jawbone device into pairing mode (click the link below to access instructions for your device)
  3. Wait for your iOS device to detect your Jawbone
  4. Tap the Jawbone device name in the Bluetooth menu to connect
1. To begin, access your iOS device's Bluetooth menu:
  • From the Home screen, tap Settings
    • Tap General (for iOS 5 or older)
    • Or tap Bluetooth (for iOS 6)
Oct 25, 2017 | Cell Phones
My samsung moment phone will not pick up my jawbone earpiece when i search for bluetooth. What im i doing wrong
power off the phone than power back up go to settings select bluetooth go to discover for 3 minutes and wiat about 30 seconds . now on the bluetooth hold down the middle button which is the answering key till it blinks blue and red than go the the phone again select search and that should show jawbone bluetooth press pair and insert 4 zeros for the password and that should solve the problem for you good luck ......rymi1982
Jun 17, 2010 | Cell Phones
Have a jawbone bluetooth ear piece trying to pair it with a blackberry cant remember how to pair it
I have two jawbone headsets and they won't pair with our blackberry phones. Can you help me
May 20, 2010 | Cell Phones
Can't connect my jawbone with my phone
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY! "
Jun 02, 2009 | LG Vu CU920 Cellular Phone
Jawbone bluetooth won't pair with phone.
sometimes the phone will not pick up on certain bluetooth headsets so i recommend a Motorola.
Apr 28, 2009 | Samsung SPH-m520 Cell Phone
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Pairing headset
you need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Cell Phones Logo
363 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
