Question about Intel D101GGC Motherboard
How many serial port slot connector are available in the motherboard''
  • 271 Answers
There is only one serial port available on Intel D101GGC motherboard.
If you need more information about motherboard then check following link.
http://www.intel.com/products/motherboard/D101GGC/index.htm
Thanks
Posted on Mar 04, 2009
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
I want to update my bios
Oh?
Kvpsy,
The information tells me;
1) Operating System: Windows XP Pro with Service Pack 3 (SP/3)
2) Processor: (CPU) Intel Pentium 4, 3.06GHz,
(Or also stated as 3.066MegaHertz) {3.066MHz}
Uses an LGA775 processor socket.
Front Side Bus = 133MHz.
(Intel processors are 'Quad Pumped'. 133MHz is the Internal Clock. 533MHz is the External Clock.
4 x 133 = 532. Number is rounded up to 533)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
Scroll down.
Prescott Core, 90nm architecture.
Pentium 4 HT model 524.
sSpec number on top of the Processor, (Heatsink removed), is either
SL8ZZ, or SL9CA
3) Motherboard manufacturer name, and model number:
Intel D101GGC
Version AAD357
3) Motherboard chipset:
ATI Radeon Xpress RC410 = Northbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
IXP450/SB450 = Southbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Southbridges_2
4) GPU: (Graphics Processing Unit, or slang = graphics chipset)
Built into the motherboard chipset; ATI Radeon 200 series with 256MB's of graphics ram memory.
(? Really? I would think more like 64MB for Integrated Graphics.
Are you running a graphics card, in the PCI-Express slot on the motherboard? Got one in one of the PCI slots?)
5) Ram Memory:
2 Ram memory slots
DDR Sdram at 400MegaHertz. Also known as PC3200.
Maximum TOTAL amount is 2048MB. (2GB)
Amount of ram memory that installed now, 1024MegaByte. (Or also stated as 1GigaByte)
960MB is what shows.
(64MB's of ram memory is being borrowed)
32MB DRAM modules. Memory module/s ('Stick') use 5 Volts (DC)
60nanosecond to 70ns, Cas Latency of 3. (CL3)
6) Harddrive:
IDE
Western Digital WD1600AABS
150GB
7) Optical Drive:
IDE (EIDE really)
Manufacturer = LG Electronics
Model number = GH22NP21
DVD burner drive
8) C-Media CMI8738 audio (Sound) chipset
9) RTL 8139 Ethernet chipset
10) Basic Input/Output System (BIOS) manufacturer = Phoenix/Award.
Version = 6.00PG
Release date = 04/20/2006
BIOS String ID = GC11010N.86A.0311.2006.0420.1525
NOW, the message you received is -
SUGGESTION: Are you looking for a BIOS upgrade?
System BIOS is more than 2 years old. (WELL NO KIDDING!!)
Video BIOS is more than 2 years old. (Yeah? AND?)
A) AS SOON as you purchase a motherboard, the BIOS program is ALREADY out of date.
BIOS upgrades are made about 2 weeks, after the motherboard hits the market.
TWO WEEKS!!
What does this mean?
It means LEAVE IT ALONE.
If everything is working OK, DO NOT perform a BIOS upgrade.
Why?
Because for;
1) IF, the power goes out to your house/business, when you are downloading, the BIOS upgrade WILL NOT be completed.
What does that mean?
Take the motherboard out of your computer, and use it for a Frisbee.
2) IF, the BIOS upgrade is too new, and/or NOT compatible, AND if you do not save the old BIOS version, take the motherboard out of your computer, and use it for a Frisbee.
IS there a cure for ruining the BIOS program in your BIOS chipset, on your motherboard, and downloading, and installing the original one?
SURE!
Take it to a PRO, who will download the ORIGINAL BIOS, to a Floppy Disk, (Or disks), using an internal Floppy Disk drive, connected with a floppy disk ribbon cable, to your floppy drive connection on your motherboard, and put it on your motherboard.
MAYBE.
(Not shouting. Illustrating a point)
OR, if the BIOS chipset is removable, (It is soldered on the motherboard), perhaps another BIOS chipset is available, for a PRO to solder the good one back on the motherboard.
You HAVE been advised.
BIOS upgrade download page,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021749.htm
Motherboard Manual,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Regards,
joecoolvette
Jun 16, 2012 | Intel Computers & Internet
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
What are the different parts of a motherboard?
The motherboard or PCB (Primary Circuit Board) is responsible for connecting all computer devices to the microprocessor. It supplies devices with power and allows the computer to react with them, Devices that can be used by connecting to the motherboard are: Storage devices, sound cards, graphic cards and hard disks.
Devices or components that are needed to make the computer work as it should, are inbuilt within the motherboard or can be connected to it using a socket or port. Listed below are sockets and ports that are available on the motherboard for connecting devices and , what that they are capable of doing.
PCI (Peripheral Component Interconnect) slot: Supports peripherals like sound cards, DVD decoders, and graphic accelerators with 32 bits at 33Mhz capabilities. There are usually anywhere from 1 to 6 PCI slots available on the motherboard.
AGP (Accelerated Graphic Port): This provides fast bus speed connectivity along with fast access to the main memory. It is designed for video cards that demand higher bandwidth.
Chipset-North Bridge: An integrated circuit that has special duties.
CPU (Central Processing Unit) socket: A socket specifically for connecting your computer processor.
DIMM (Double Inline Memory Module) slots, SIMM (Single Inline Memory Module) and RIMM: Different types of memory (RAM) can be installed into these slots.
Motherboard Battery: A battery compartment, which stores the battery used for storing data such as system date and time, when you shut down your system.
IDE Connector: Responsible for connecting the IDE cord used for hard disks, CD drives, and DVD drives.
Firewire header (IEEE 1394): A serial bus used to exchange digital and audio data with high performance abilities.
The following listed items are parts that are built within the motherboard with specific connective uses such as keyboards, mouse, and printers.
PS/2 Connectors: Each motherboard usually has 2 PS/2 connectors for the keyboard and the mouse.
USB (Universal Serial Bus) port: There are usually a couple of these ports located on each motherboard used for connecting pen drives and external hard drives, like Ipods or Mp3 players.
Parallel or (LPT) port: The place used to connect scanners and printers.
Game Port: The port to connect all gaming devices for example, a joystick.
Sound Card Connectors: Plug in your microphone or speakers here.
Display Connector: Connecting your monitor to the motherboard.
COM (Communication) port: The port designed to connect your mouse and modem.
Jun 18, 2010 | Intel Motherboard
How-to use the serial port header on DG31PR motherboard?
I tried this serial port using a simple connector that i found in another computer. its a simple straight cable. It's configuration is little different means pin configuration is change. I am developing a robot that will receive data from serial port, but it damaged one of IC (MAX232) on PCB. when i checked the voltage level i was surprised that its not simple +- 5 V its almost 24 volt.
Jan 01, 2010 | Intel DG31PR Motherboard
PRINCECHARMING2010@YAHOO.COM
CPU
  1. LGA 775 for Intel® Pentium® D / Pentium® 4 processor
Chipset
  1. North Bridge : Intel® 865G GMCH
  2. South Bridge : Intel® ICH5
  3. Realtek ALC653 Codec
  4. EP82562G chip (10/100Mbit)
Front Side Bus
  1. 800 / 533 MHz FSB
Memory
  1. Type: Dual Channel DDR 400 / 333 / 266 support
  2. Max capacity: 2 GB
  3. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. Internal I/O Connectors
  1. 1 20-pin ATX power connector
  2. 1 4-pin ATX 12V power connector
  3. 1 floppy connector
  4. 2 IDE connectors
  5. 2 SATA connectors
  6. 1 CPU fan connector
  7. 1 system fan connector
  8. 1 front panel connector
  9. 1 front audio connector
  10. 1 CD In connector
  11. 1 power LED connector
  12. 1 USB 2.0/1.1 connectors for additional 2 ports by cables
Expansion Slots
  1. 1 x AGP 8x slot
  2. 3 x PCI slots
Back Panel Connectors
  1. 1 PS/2 keyboard port
  2. 1 PS/2 mouse port
  3. 1 parallel port
  4. 1 serial port (COMA)
  5. 1 VGA port
  6. 4 USB 2.0/1.1 ports
  7. 1 RJ-45 port
  8. 3 audio jacks (Line In / Line Out / MIC In)
Form Factor
  1. Micro ATX
  2. 24.4cm x 21.2cm
H/W Monitoring
  1. System voltage detection
  2. CPU temperature detection
  3. CPU / System fan speed detection
  4. CPU warning temperature
  5. CPU / System fan failure warning
  6. CPU smart fan control
BIOS
  1. 3Mbit flash ROM
  2. Use of licensed AWARD BIOS
Other Features
  1. Supports @BIOS
  2. Supports Download Center
  3. Supports Q-Flash
  4. Supports EasyTune 5 (only supports Hardware Monitor function)
  5. Supports Xpress Install
  6. Supports Xpress Recovery2
  7. Supports Xpress BIOS rescue
Remark
  1. Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
  2. Due to most hardware/software vendors no longer offer support for Win9X/ME. If some vendors still has Win9X/ME drivers available, we will publish on website
Jan 16, 2009 | Computers & Internet
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
I don't know the parts of the motherboard.
What motherboard would you like to know the layout of? Although, many motherboards are different, most of them have the same basic parts. From back to front, you have the communication ports; (usually from top to bottom, varies by manufacturer)mouse/keyboard, usb 1.0/1.1/2.0(make and model dependant) serial, paralell, vga/monitor, then sound: midi, headphone/speaker out, line out, microphone in.
then on the board, processor, somewhere near it, cache, i/o chip, north bride chip, wich is responsable for memory(ram) access, ide(cd rom/ hard drive access) ports and power connector/s,
memory slots
then the south bridge chip witch controls isa port(old), pci slot, agp/pci-e slot (video card) along with the cmos battery, bios, and various other slots/connectors (such as fan, power button and so on) and chips, wich vary by manufacturer and model.
Dec 27, 2007 | Computers & Internet
Intel D101GGC Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
