Question about RIM BlackBerry Curve 8310 Smartphone
...turns off when I touch the trackball...
Well the phone was dropped and now when you turn it appears ok, until you touch the trackball, then it re-starts.
  • 50 Answers
Its ball jacket has been damaged...try to replace it and its the only solution...or it will cause more severe loss of your device.
Posted on Mar 04, 2009
How can i clean my micromax q5 mobile trackball
hi yashu, use ethanol or isopropyl alcohol to clean the ball. turn off the phone, just wet a lint-free cotton cloth with 2-3 drops of above mentioned chemicals (u can use petrol in worst conditions) and slowly rob and roll the ball. allow the ball to dry. start the phone enjoy.
May 24, 2011 | Cell Phones
My Ipod touch screen suddenly began to display everything huge. What happened?
Hi mariaelenaga,
To set a minimum font size for messages:
Choose "Mail, Contacts, Calendars" > Minimum Font Size, then choose Small, Medium, Large, Extra Large, or Giant.
Also, you may need to try the following:
Restarting and Resetting iPod touch
If something isn't working right, restarting, force quitting an application, or resetting iPod touch will likely solve the problem.
Restart iPod touch: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPod touch. To turn iPod touch back on, press and hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPod touch or if the problem continues, you may need to reset. A
reset should be done only if turning iPod touch off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPod touch
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPod touch: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
This information was sourced from the iPod Touch official user guide at:
http://manuals.info.apple.com/en_US/iPod_touch_3.0_User_Guide.pdf
Hope this helps.
Best regards,
CellPhBuddy.
Mar 17, 2011 | Cell Phones
My Droid X is stuck in a mode where it rotates between the "robotic eye" and droid. I have taken battery out several times, restarted it, and when it is on, I cannot turn it off. Any ideas...
Try doing hard reset but it will erase everything. Please save all your data before doing this. Hopefully it works.Do this at your own risk
Steps to Reset Phone when phone is turned ON
  1. Touch Menu > Settings > Privacy > Factory data reset > Reset phone.
Steps to Reset Phone when phone is turned OFF
  1. With phone turned OFF, press the Home key and Power button simultaneously. The device will power on. Keep holding the buttons down until Recovery screen (exclamation mark in triangle with android figure) appears.
  2. Press the Search key.
  3. Touch wipe data/factory reset then touch Ok.If the touch screen is not functioning, utilize the Volume key (up/down) to highlight and the Camera key to select.
  4. Touch Yes--delete all user data and touch OK.This will bring back the device to factory settings.
http://www.resetcellphone.com/solution/Motorola/droid-x
Feb 22, 2011 | Motorola Mobility Droid X
My trackball cannot sroll down . its stuckk ..
Hi
To unstick your trackball,you need some rubbing alcohol
Pour a few drops of rubbing alcohol directly on your trackball,you can use a dropper to do this.
Roll the trackball around continuously until it starts to work again
Jul 30, 2010 | Computers & Internet
The centre scroll button doesn't 'click'
As you use the trackball on your Blackberry, dirt and oils on your fingers get into the trackball assembly.
You might get some 'traction' on your track ball if you lightly dip a cotton swab in some rubbing alcohol. Swab the trackball, then do a quarter turn, continue until you cover the whole trackball in each direction.
If you get no improvement, then its another defective trackball, and you'll have to return it where you got it; most companies warranty phones 90 days from the date it was replaced.
Jun 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
Touch screen inoperative, buttons work
Hello
I have the same problems on my iTouch as well, here is what i do:
  • Restart the app
  • Reinstall it
  • Search for a newer version
Make sure u have the latest ipod touch firmware ;)
Feb 12, 2009 | Apple iPhone Smartphone
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Sidekick 3 trackball problem
blow into the trackball area really hard..should dislodge some particles on the sensors.
Mar 28, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Buttons and Trackball not working.
Thanks so much "GrinningFool", your solution worked perfectly!!!
Jan 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
