Question about Philips 43P8341 43" Rear Projection Television
I have green outlines in the pictures - Philips 43P8341 43" Rear Projection Television
    Problem Solver:
  • 14 Answers
Go into your menu there should be something called convergence in the menu a red and a blue convergence. when you select one you will get a cross in the center of your screen use the selection keys to move this so the two crosses are on top of each other. once you align both the red and blue ( the green is the base) then go to the multi point convergence if all crosses are lined up you are good if not then you will need to replace the convergence I.C. for that color or both. let me know how this turns out.
Posted on Mar 23, 2009
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and I have green outlines in the pictures - 2c07611.pngeplaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
Green staticy looking outlines
What is model no and brand of your tv ?
How old is your TV?
Have you changed or replaced any parts recently ?
post back this details
SAM ANDERSON
Sep 23, 2008 | Televison & Video
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
Green outline/shadow on dark images or backgrounds
LVDS Cable is corroded - This is the cable the provides video from the TV Video Process board to the LCD Panels Timing Control Board.
Honestly, if you can take the TV back do so. If not, Service it using the manufacturer warranty
Jun 24, 2009 | Vizio Televison & Video
Picture is messed up
need to replace convergence control chips
Jun 12, 2009 | Televison & Video
Purple/Green Outline surrounding picture
I have seen two different things cause this. The first and most common is the electrical failure of one or both convergence IC's. A handful of times, the data in the DCU became corrupted and I was able to enter the service mode, go to manual convergence and correct the one location that was off.
Apr 28, 2009 | Toshiba 50HDX82 50" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
