Question about Sony PlayStation Portable (PSP) Console
Out of nowhere, my PSP won't turn on. I even got a new battery and it still won't. HELP!
  • 81 Answers
Hardware failure
Posted on Mar 04, 2009
My kodak easyshare m320 won't turn on or charge
I would wait until your battery comes in, if there is no change then yes I would take it in to have it assessed with a estimate first giving the option to go ahead or not.
Jul 07, 2012 | Kodak EasyShare M863 Digital Camera
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Psp won't turn on. got new battery.
Did you try to use the charger and turn on the PSP? If you use the charger and the psp turned on, the problem would still be the battery, you bought a defective one and have it returned where you bought it. If it did not turned on using the charger, the problem would be internal, a micro fuse might have blown up and needs to be replace. An experience technician in PSP could replace it, because it needs to use soldering.
Hope that helps you out!
Jul 03, 2011 | Sony PlayStation Portable (PSP) Console
Im using psp 3001 with version 5.03 PROME-4...Ads by GoogleInflatable Movie Screens www.OpenAirCinema.usSeamless, high quality screens Portable, washable, outdoor screens By richmond_sic on Mar 07,...
You should have not installed ChickHen in your PSP 3001 since there are no known ways so far, not even by Dark Alex, to fix it from "Brick"-ing. YOur attempts to remove the battery and so on to fix it is futile because even Pandora Battery and Magic Memory Stick won't work on those versions of PSP.
Try sending it to S0ny...
If you intend to buy a new PSP, either buy those Slim that is version 2000 and those that are NON (remember NON) TA088v3 MoBo. From this MoBo onward to PSP 3000s, all is unhackable and cannot be fixed from Brick.
May 31, 2011 | Sony PSP (Piano Black)
Comes on And Blinks off
I have the same problem- try gettin a new battery
Oct 18, 2009 | Sony PlayStation Portable (PSP) Console
My psp dosn`t turne on any more.any help?
do you install custom firmware? coz if you do maybe it got brick. try using pandora battery if it works. if it still dosen't works you may have a hardware problem.
Jul 19, 2009 | Sony Video Game Consoles & Games
PSP
some key questions 1: is the light turning on 2 was it used?
Answers if the light the green power light is turning on and it was used turn the thing back in cause you baught a bricked psp theres this thing called a pandoras battery if you have a friend thats good with psps he can help you 2 If you bought a new psp then your daughter bricked it som how...psps are very complex there motherboard can be damged or wiped out by turning the psp off during a update id find somone whos good with psps that has the bandoras battery thing ask everyone you know about it daughters friends anyone pandoras battery they could help you thats what i did.
Jan 03, 2008 | Sony PlayStation Portable (PSP) Console
PSP Won't turn on
Try this>
Start with the PSP turned off. Press and hold the R button when your turning on the power. Turn it off again, then back on. Sometimes this works. If not, your PSP is probably Bricked.
This means that you done something to interupt an upload or program in progress. The eeprom program is corrupted and the PSP will not boot up. The term Bricked, refers to your PSP being no better than a black Brick paper weight. I have heard of a repair for this called Pandoras Battery. I am not sure if the Pandoras battery really works to restore Bricked PSP's. It may be worth a try for you to take a chance on Pandoras Battery.
Nov 07, 2007 | Sony PlayStation Portable (PSP) Console
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
