Question about Kenmore Vacuums
Burning smell kenmore canister
Model 116.27614700 motor smells hot when running. the copper cylinder (armature????) inside is blackened, the copper brushes???? u can see the wearing. tried to clean. model approx. 1 1/2 yrs old. other than sears where can u get parts to replace this or new fan motor unit. or can this be oiled or cleaned?
sears part number KC92FCJNZ000
thank you
lori
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Posted on Jul 12, 2012
    President:
  • 2,976 Answers
Any reputable vacuum cleaner repair shop can check it for you. It will have to be a multi brand shop, nit a Kirby, or Electrolux thpe. They are dealers and only repair their own brand.
Posted on Mar 04, 2009
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Motor is making a knocking noise with a burning smell and sparks can be seen when switching on
Sounds like ur FiLTER is CLOGED!
Air was blocked going in the motor thats why ur smeling smething burning, means ur motor is starting to overheat!
Spark in the motor is NORMAL when the CARBON BRUSHES is touching the ARMATURE!
My suggestion is to CLEAN & WASH the filter or buy a NEW one!
Hope that cleans evrything on ur probs!
Dec 04, 2010 | Dyson DC08 Cylinder Bagless Canister...
When I turn the vacuum on it sounds really loud, louder than usual, and after a few minutes it smells like burning rubber around the canister. The vacuum is still sucking.
The armature is probably missing a plate and the motor is about ready to burn up, but check the filter and screen on the bottom of the motor first. The screen can be checked by removing the filter and looking up at the motor from below. Clean if necessary by removing the motor. Unplug the unit first. If the motor sounds rough and smells like something electrical burning. It's going to need to be replaced. Check your model # and order a replacement. Pretty easy to install if you get the right motor. Get the foam gasket for under the motor if your replacing a three stage motor.
Jun 06, 2010 | Electrolux Centralux Vacuum
Vacuum is making a burning smell from the motor/fan.
Actually the screws to access the motor on Kenmore canisters are located underneath of the foot pedal that retracts the cord reel, and there's usually also two screws that underneath of the tool lid arms.
You may access the screws underneath of the cord reel by prying the foot pedal off of the vacuum. Simply put a flat head screw driver in between where the foot pedal and the vacuum cleaner meet on the top of the machine, and pry upwards with the screw driver. Once you remove the pedal you'll see the screws and have direct access to the vacuums motor.
If you are trying to access the power nozzle motor, here's a detailed step by step instruction tutorial that will walk you right through it.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
When a vacuum cleaner smells like something is burning, it can only really be one of two things. Either the rubber belt inside of the power nozzle is burning, or the motor is burning. If it's the belt that's burning, it will be a burning rubber type of smell, but if it's the electrical motor, it will be more of an electrical smell.
If you have any further quesitons, please feel free to reply using the clarification request tool here on Fixya. I'm always more then happy to answer any follow up questions.
If this was helpful, please rate my repair by clicking the thumbs up icons in the top right hand corner of this repair.
Thank you,
Chris J.
GoVacuum.com
Apr 11, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore vacuum model 116.3592250 works fine, burn smell
is that the one with the direct drive brushroll? those brushroll motors inside the brushroll always go bad. that is one of the worst designs from kenmore. is the brushroll turning?
Dec 31, 2009 | Vacuums
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Rainbow E series
The belt looses it tensile strength (tightness) over time. But it's the part about funny sounds and shutting down that concerns me. If it smells like a tire fire then it's the belt if it smells like plastic and burned hair then the motor has a bad field or armature. Probably one of the carbon brushes got hung up and burned a segment in the armature.
Oct 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
937 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
