Question about Dell Inspiron 1525 Laptop Jet Black
Error message Please can you tell me what to do? on my 1525 dell laptop that stop booting to windows. the message below are the error. checking file system on C: the type of the file system is NTFS. one of your disk check, but it is strongly recommended that you continue. window will now check the dis. CHKDSK is verifying files (stage 1 of 3)...115328 file reconds processed. 0 bad file reconed processed. 0 EA reconed processed. 49 reparse reconed processed CHKDSK is verifying indexes (stage 2of 3)... 65 percent complete. (127102 of 14018 index entries processed) regards ify
    Problem Solver:
  • 6 Answers
That is not an error, Windows is trying to verify that there are no issues with your hard disk. Is what you wrote above all that you see? If so then check disk is freezing before it completes. Try to cancel the chkdsk before it starts by pressing any button when it prompts you to, log into windows, back up everything up that you need and restart your laptop. Worst case scenario you need to reinstall windows on your laptop
Posted on Mar 04, 2009
Nable to go anywhere . Whats the problem PLEASE HELP>A blue screen with message "CONFIG_LIST_FAILED has apperared on my Dell Inspiron 1525 , also, STOP OX00000073.
John Holland,
Click the link below for instructions on resolving this issue. You will need to boot to your windows disk and run a repair install.
MS Answers error resolution
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 18, 2013 | Dell Inspiron 1525 Laptop
I have a Dell Inspiron 1525 and when I turn it on it tells me NO BOOTABLE DEVICE DETECTED This happen one other time and I rebooted my computer and it came back on but it did not work this time what can I...
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key"
There may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the hard drive and also where it connects to the motherboard.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Sep 16, 2012 | Dell Inspiron 1525 Notebook
Inspiron 1525 Error Code 4600:021E msg: Processor
There are several Reasons.
  1. Your Processor heated up more than the expected limit. Often caused by a trouble with Heat-Sink(and or the Copper tunnel if have one inside), Short Circuit. You have to check the Processor and its Socket.
  2. CPU fan is not functioning: You have to check whether the fan works properly (with a good speed - rpm).
  3. Your Sensor has a fault. You have to check the Sensor.
Jun 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
DVD Write error in Dell Inspiron 1525
This issue may can be of Nero means product of DVD wrighter, Now you should uninstall the nero from Add or Remove programe also remove from registry and again install Nero after completing this process you should try for wrighting DVD.
I hope that this has been very helpful for you
Dec 12, 2009 | Dell Inspiron 1525 Laptop
Unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Windows Vista Start up problem, reboots automatically.
Boot to recovery console using XP CD, run CHKDSK /R and see if that resolves.
If no go, try a reinstall of windows, if still no go, then replace HDD
Sep 28, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Windows boot manager file: /boot/bcd status: oxcoooooe9 info: an unexpected I/o error has occurred I am experiencing the same problem on a Dell laptop (Inspiron 1525: Windows boot manager - file:...
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
May 09, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Laptop Jet Black  Logo
143 people viewed this question
Alun Cox
