Question about Nokia N70 Cellular Phone
How to fix my MMC, when insert it on my phone, it appears mmc corrupted then it will ask to format now. When I press the yes button there's no responce. What should I do? I also tried to insert it to MMC card reader but also the same I can't open it says there's something I/O error something like that. Can somebody help me? =
  • ranasandeep5 Mar 04, 2009
    when I insert memory card it shows corrupted
    Problem Solver:
  • 6 Answers
Put it on your card reader and then then find it in to your my computer then right click>format: FAT chek the quick format and then start>then go again in my computer right click on your mem card then click properties>tools> there you will find Error-checking...click check and then check all the boxes then start.....w8 for it to complete fixing errors on your MMC then try to put it on your phone...
hope it will help....
note: it must be FAT not FAT32 coz i tried it, it shows again the mmc corrupted.... but when i tried FAT format and then put on my 6630 it worked again.
Posted on Apr 15, 2009
It is askin me for a security code to format my memory card
Maximum all phone ask for lock code for format mmc.
Follow these steps to format your mmc.
1. Connect you phone with pc using usb data cable.
2. Once phone connected it ask which mode prefer to connect (mass storage, pcsuit and others)
3. Select mass storage.Now two drives will appear on my computer one will mmc and one will phone.
4.check carefully which one is mmc by opening properties of mmc.(should be greater then phone drive).
5.Now right click on mmc drive and select format.
6.then ok to format(click yes to warrning).
7.this way you can formate without lock code.
Apr 20, 2011 | Cell Phones
I need to upload video from camera. I put the memory card in the UBS and plug into computer and it says that it has failed to locate supported file types
maybe you experienced this because off virus or a corrupted file.
* fisrt try to insert the mmc to the pc,when the mmc folder appeared and no dcim folder appeared try to click the tools and folder options then go to view,check the show hidden files.,if the folder already appeared back up the pictures that detected by your computer to the other folder.,and after you backed it up try to format it.,if the formatting run normal.,then try to format the unit in the menu settings,.after that youll need to insert the mmc again in the tl220 then take 2 to 3 pictures.,if you preview the 3 pictures then remove the mmc to the tl220 then copy the pictures that youd been backed up.
*second if you inserted the mmc and the dcim folder was too none highlighted like the other folder, press he right click go to properties - unchecked the read only and hidden - apply - ok to the sub folders and folder - ok..then reinsert the mmc to the unit.,then preview the pictures.,
Jan 28, 2011 | Samsung L200 Digital Camera
HOw to format memory card , whenever i restart my phone , It ask me to format memory card, but i donoy know the code Please help me How to format even i have format from PC and did Master Reset from...
If that would be your case that the phone is always asking you to format the MMC, your MMC could have been damaged or getting into being corrupted, please try using another MMC, and reformat it, then re-boot the phone, see if that works.
If that works(your other MMC) it simply means that your MMC is corrupted or faulty, have it replaced (buy a new one)
Sep 20, 2010 | Sony Ericsson K530i Cellular Phone
Mmc is not detected in the phone (it says "mmc is corrupted" ) though it opens in pc. I hav formatted it with fat option (hard format and not Quick format).other mmc if inserted show the same problem....
Try to read your memory card with your computer, use memory card reader, if problem same. it's say mmc corrupted, need to format also, that mean your memory card damage already.
Jun 24, 2010 | Nokia 3230
When i insert memory card phone says format memory, if i press ok button it says cannot format then memory was not reading
Hello friend,
  • MMC might be Corrupted
  • Check by putting other MMC into your phone jack
  • If Phone jack is ok you have to Clear MMC
  • You can put it in to CARD READER through PC
  • and manually Format it
  • You are done
You are solved .....Enjoy....!!!!!!!!!!!!!!!!
If you helped this post Rate me.........
you can feel free contact me.......
Mar 29, 2010 | Sony Ericsson K770i Purple 3G Camera...
Not able to reformat 512MB MMC card of NOKIA N72
make sure you formatted it to fat32,then put back in the phone(without the music yet)back up phone to the mmc card.. when you have done that find the music folder on the mmc card and put your songs in there.
Jun 03, 2009 | Nokia N70 Cellular Phone
MMC locked nokia 6270
mmc locked how can i open 6270 he asking 8 digit password
Nov 22, 2008 | Nokia 6270 Cellular Phone
Corrupted mmc
i cannot actually get what is the problem here but if you trying to ask how to format the mmc you can use a card reader that has an MMC slot. this can be displayed automatically on your windows explorer. right click and choose format to format the MMC.
Please Rate Thanks
Jan 14, 2008 | Nokia N70 Cellular Phone
MEMORU CARD CORRUPTED
try by restoring handset once a time or else memory card is corrupted..change it....
Oct 18, 2007 | Nokia N70 Cellular Phone
Regarding mmc card
according to me if your cellphone is in warranty then you should change your mmc card with new one because as i think your mmc card is corrupted.
May 12, 2007 | Nokia 3230
Nokia N70 Cellular Phone Logo
182 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
