Question about Canon PowerShot A630 Digital Camera
How to reset cmera to default settings.
-pictures come out darker, even in auto focus. How
  • Anonymous Mar 28, 2009
    The camera then says busy and won't reset.
  • 423 Answers
Hi there and welcome to FixYa.
To reset your camera do this:
Press the menu button.
Scroll Right to the setup menu.
Scroll down to Reset All
Select OK and press the Func/Sel button.
Hope that helps. If you need the manual, you can find it here
http://gdlp01.c-wss.com/gds/0900001226/PSA640_630CUGad-EN.pdf
Rob
Posted on Mar 04, 2009
Why do I get blurry pictures on screen even when I'm focusing.
Go to MENU. Then TOOLS. Make sure Motion Detection is in AUTO.
If that is on AUTO then Put the camera on a hard surface (like tripod) and focus and see if image is still blurry. Lastly, it is difficult to focus in some conditions. Move the focus point, you can click on the screen to change it. Blur can be caused by: long exposures, camera motion during photograph, bad conditions unable to focus.
The focus routine in this camera gets confused often. It can be frustration. It will only be in focus when it is GREEN before you shoot and the camera is not shaking. At night it can take great night shots with a TRIPOD and Exposure set to -1 to -2.
Dec 07, 2014 | Nikon Coolpix S4000 Digital Camera
I am havin Sony Dsc-190 camera, the problem is pictures are not clear and I cnt increase the iso level, so pls help me out.
So the problem here can be many things.
  1. Either the camera is not focusing well
  2. the lens is not clean
  3. there is condensation inside the camera
is it possible if u post an image taken with the camera itself. also try checking if the camera has a master reset just in case u have set something that caused the auto focus to get disabled. like this you will reset the camera and get the auto focus back working.
the iso level will only control the lighting in your camera, so it will enable you to take pictures in darker areas when the iso goes higher. if your camera does not let you control the iso its probably set on auto.
regards
May 12, 2012 | Sony Cameras
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Bought a Nikon P100 to replace a basic point and shoot dital camera. With children in sports, a shot from the stands is hard to 'get.' Now, all I get is blurry messes, unless it's in auto mode. Even the...
This camera is a bridge between the Point & Shoot (P&S) types and a "full blown" dSLR camera. It is very complex when compared the P&S type.
There are many areas of the manual the discuss the focus procedure, but you might want to simply perform a "RESET ALL" on the camera. This will return all the settings to their DEFAULT factory settings, thereby clearing any custom setting that could be responsible for the problem you are having. The instructions on how to do this and the settings defaults are shown on pages 171 through 173 of the manual. You will probably want to review them quickly before initiating the process.
After the reset, try taking some pictures to verify the focus works again. Next, feel free to change any setting from the default to one of your liking. Be sure to take a picture after EACH setting change to make sure you don't find yourself in the same situation again.
I hope this helps. Please rate my reply - thanks!
Jan 11, 2011 | Nikon COOLPIX P100 Digital Camera
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
My pictures are very blurry.. We have reset to the default settings but the pictures are still coming out blurry... This was not a problem before as we have had clear pictures. What do you think the...
The auto-focus might be bad. Set to manual focus and see if that works. If not, then the focus motor is slipping or the motor itself is bad and cannot focus the lens properly.
Nov 03, 2010 | Polaroid i835 Digital Camera
My screen has gotten much darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Picture has gotten darker
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
My Canon Powershot SD630
What do pictures taken at night/poor light look like ?? if they are an improvment ,
your Exposure/Auto-Light/White Balance settings may be horribly configured.
Firstly I'd try Resetting the camera to default settings by using the settings menu .
>Menu >Settings >Reset default settings
This should eliminate poor settings as a suspect for the problem.
Sep 28, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot A630 Digital Camera Logo
415 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
