Question about Microsoft MN-700 Wireless Router (p5308j)
Weird MN700 hassle...
I am connected through Qwest DSL, the modem is an ActionTec M1000, and the Wireless Router is a Microsoft MN700. This problem wasn't happening before, so I am assuming it has something to do with reconnecting with a different account (customer account, same hardware and ISP as before).
Before, on the prior account, I was able to connect to 192.168.2.1 (The default IP address for the Base Station) while it was connected to the modem. Now, I can not connect to the wireless router (I was using MAC filtering to prevent certain people from leeching off our bandwidth, since when they are connected our downstream goes to like 1.1 MBPS) when it is connected to the DSL modem. My guess is that the modem is randomly assigning an IP address to the wireless router everytime it connects, and defaulting back to 192.168.2.1 when not connected. In any case, what can I do to ensure that the wireless router STAYS at that IP address, so that I don't have to disconnect the service to manage client filtering?
  • 611 Answers
Can you tell modem has the 192.168.2.1 ip just chage into different
Posted on Mar 04, 2009
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
How do I reset the password and User ID on an Q1000 Actiontec Modem?
Things You'll Need
• Q1000 Qwest Wireless N VDSL Modem Router
• Computer connected to the Modem
Step1 On any computer that is
connected to the Internet, type http://192.168.0.1 in the web
browser window and then press Enter.
Step2 Click Utilities.
Step3 elect "Restore Defaults" from the menu on the left.
Step4 Click the last restore button that follows
"Restore Modem to Factory Default State
The manufacturers web site with this advice is here.
http://www.actiontec.com/products/datasheets/Q1000QwFactoryDefaultsHowto.pdf
Sep 24, 2014 | Actiontec Qwest Model Q1000 4-port...
How do i conect to my wirless router setup
MAKE SURE THAT YOUR LANDLINE IS CONNECTED TO YOUR WIRELESS AND THEN FOLLOW THE INSTRUCTIONS ON THE DISC
Jul 23, 2012 | Actiontec Qwest Branded - Centurylink...
How do I connect to a qwest dsl m1000 modem
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
Recently upgraded DSL speed which required new modem (Q1000, Actiontec) which in turn stopped xbox live from getting a connection with older wireless router, bought the microsoft wireless N which is stated...
I gather from reading this that you have another router that is connected to the Actiontec. The Xbox connects to the other router. You need to check the settings on the other router and the modem to see if the DHCP is enabled, also check to see what the subnet is set to. Make sure they all match. Then check those settings on the x-box.
Nov 13, 2017 | Microsoft Wireless Network Adapter Xbox...
I have an Actiontec wireless modem from Qwest and I cannot find the SSID
If you haven't changed your SSID, the default SSID is provided on a sticker on the bottom of your Actiontec router. It usually starts with a JR
Nov 10, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can a actiontec gateway wireless DSL router be connected to a comcast cable modem?I have an old DSL wireless router (gateway), can I use this as my wireless router with comcast cable internet, or do i need...
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Nov 08, 2009 | Actiontec (GT701WG) Wireless Router
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Apple user attempting to fix dad's dell laptop windows xp home edition
I'm confused because you say your trying to make a lan connection on the dell laptop but your connecting it via firewire into a DSL modem. doing this method would be a WAN connection and not a LAN connection. To make a lan connection you need to connect the laptop via network cable (or wireless connection) to a router that is connected to your actiontek dsl modem.
I can help you connect the laptop to the internet but 1st i need to know if your trying to connect it to a router or did you want to do a wan connection from the dsl modem.
Thanks,
Brad Nelson
Mar 15, 2008 | Actiontec (GT701WG) Wireless Router
Microsoft MN-700 Wireless Router (p5308j) Logo
155 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
