Question about Canon BubbleJet i560 InkJet Printer
Cannot remove the print head from canon i560 printer
  • Da Z Mar 17, 2009
    Can get the cartriges and piece benieth but not the print head itself.
  • Anonymous Mar 30, 2009
    missing black across the page
Try this - open cover on printer
on the right side of the cartridges is a grey arm - lift it up
remove all ink cartridges.
then remove print head.
Posted on Mar 08, 2009
SOURCE:
SOURCE: canon i560 printer
cd driver canon i560
Posted on Jan 30, 2008
It's likely the print head is clogged. You have 2 options:
1) Remove and clean the print head. Open the printer and lift the gray lever and just pull out the print head. There are no tabs to push, it simply slides out. Search the web for cleaning techniques. Looks like people have tried hot water, isopropyl alcohol, and ammonia. I don't know what the best technique is. It's probably a good idea to finish with a distilled water rinse and soak up the excess water with regular towels or paper towels. Remember to clean the ink jet at the bottom of the print head and not the electronic circuitry at the back of the print head.
2) Buy a replacement print head for $50-$65 off the web.
Hope that helps :-)
Posted on Jan 06, 2009
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
e-ware
  • 776 Answers
SOURCE: Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: Is it worth buying a new print head for i560
Why do you think the head is bad? Treated with care, these things are bulletproof.
I have an i560 which was discarded but clean. I first ran a test page and the printer worked fine, but with many streaks.
Part of that was "fuzz" stuck under the head wiping across the paper. The other part was clogged jets. Here's the cool part.
This head is built like a tank and is very easy to remove and unclog.
First always remember, NEVER place the head jets down on anything or touch them with anything other than LIGHT pressure with a soft paper towel or cloth.
Remove all 4 ink tanks and if they have a decent amount of ink in them, and are not very old, carefully place them upside down somewhere safe, label side down, ink pads up. Work quickly to minimize ink evaporation this point forward.
Remove the head assy. lifting the blue latch on the right side. It's pretty spring loaded. This will completely release the printhead.
Carefully pull the top part forward, then up and out. Don't touch the gold contacts but do check visually to see if they're clean. If not, a soft damp cloth will likely clean it up and get old ink off.
Use a small plate with about 1/2" of warm water and holding the printhead by the edges, place the jets just into the warm water. The water will instantly start to turn brown from all the ink. Using a dry soft paper towel or cloth, take the head and gently press the towel onto the metallic jet assemblies and draw out all the old ink. You will see black from the K jets, and tri-colors from the CMY jets.
You can repeat this with clean warm water again. Remember not to take a long time as your ink tanks are sitting open. 10 minutes should be more than enough time.
Use wet qtips to clean old ink from around the inside of the head, where the tanks go, around the outside of the round silver screens. There are rubber seals there and you want those clean. The screens are very delicate and do not touch them with anything.
Use dry qtips to remove all water from the seals and any other area in the head assy. Again, do not tough the screens.
Finish by using a damp towel to very gently wipe down the bottom side and the ink jets. A little more ink will probably come out into the towel.
Once everything a dry, place the head carefully back into the printer locating the bottom, jet part first into the carriage then push the top part with the contacts toward the back to seat it. make sure it's all the way in by slightly "jiggling it". It should not move around and be "in".
Move the blue latch to the down position to lock in the head.
Replace the ink tanks but make sure ink is not leaking out the bottoms as this indicates a bad seal on the tank and it's a gonner.
Close the printer cover and let it complete the automatic cleaning cycle.
Print a test page:
With the printer on and idle, press the right paper eject/cancel button and hold it down until the green light flashes off-on TWICE then remove your finger. It goes like this "hold down button, green light goes off, flashes on-off...on-off... release button!
This triggers a 4 color test print and will show all the black jets and color strips for the color jets.
If everything is clean (and it's going to be a LOT cleaner now!), you should see nice even colors and a nice stairstep pattern at the top for the black with no missing lines.
If it's pretty good, but has some minor issues, you're close.
You can open the printer and repeat the warm water procedure.
One other thing I did you really clean out all the old ink was to use an eye dropper and place a drop of the clean water on top of the metal silver screens. Then gently press a towel up on the ink jets as before. You will see the water sitting on the screens disappear as it's drawn into the jets and you will see even more ink coming out.
This should give you a brand new printhead.
If you see any debris or ink or discoloration on the gold contacts (they should all be shiny gold), you can gently use a damp CLEAN towel to gingerly wipe off the debris.
As a last resort, if some look discolored, and SOFT PLASTIC eraser (like Mars Plastic) can be used to clean them using minimal pressure. Any eraser dust must then be brushed off with a soft brush, or a damp CLEAN towel followed by gentle wiping them dry.
In my case a poorly operating head to this day (years later) prints totally perfectly as if new.
Despite what DocPlayer claims, these heads are solid, meant to last (as opposed to the throw-away ones) and are durable.
The most vulnerable part are the ink jets themselves with are highly precise and tiny and easily damaged through carelessness.
Treat them gently and with nothing other than soft paper towels or cloth so they cannot get scratched, and assuming there is not any damage to them, you should have a brand new head.
I have resurrected these heads myself and every time, they cleaned up and run perfectly.
Finding new replacements, I suspect, would be difficult and likely not worth the cost. So there's noting to really lose cleaning it up if it's not working well. The odds are on your side it will work great.
HP printers can be as cranky as AnY inkjet. Even the i560 hates to sit unused. All inkjets need regular use to keep them happy. I don't care who makes it. They all rely on liquid ink which when sitting long enough, starts to dry. Simple physics.
Printing a test page (two blinks) is easy, doesn't need a computer even connected, and excersies the printing plumbing. I try to do it at least every two weeks or so and everytime I have a print job I need to do and the printer has been idle for a few days.
One more thing. Try not to unplug the printer and always keep it powered when it's turned off. There are internal timers which keep track of idle time and perform different types of head cleaning automatically.
If the printer loses power, it loses the timers and you will then force it into doing a full cleaning cycle which consumes a significant amount of ink when it's not necessary.
Also avoid opening the cover often and for long times as this also gets timed by the printer and will cause a cleaning cycle due to the fact it has left the inkjets exposed to the air.
When parked, the jets are sealed by rubber covers when not in use keeping them moist.
Good luck.
Posted on Dec 03, 2010
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
My canon i560 printer is printing on half the line or skipping a line , Ive changed the black cart. still doing the same thing. Thanks for your help RON
The print head is clogged.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number now is QY6-0064 because the old QY6-0042 is discontinued.
Nov 02, 2009 | Canon BubbleJet i560 InkJet Printer
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer
Hope that helps :-)
Jul 23, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function :
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
528 people viewed this question
Clive
Clive
old marine
old marine
