I want to put text on a t shirt and cannot figure out how i do this on my printer can you help
SOURCE: Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
SOURCE: how do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
