Question about Brother IntelliFax-2820 Laser Fax
It reads close back cover when i close the back cover it continues to say the same thing and wont let you do anything elese has anyone else had this problem ? if so how did you solve it
  • 916 Answers
* Open the back cover
* Pull the flap down that hides the orange roller on the fuser
(Careful it's Hot on that fuser!!)
* Locate the thin piece of plastic that runs from the centre to the right hand side. This bar is the problem
* 3/4 along the right hand side, there is a sticky out bit on this bar that should sit in a hole.
* I have found three printers where this was not located properly. Once I located it properly, the 'door open' error went away.
This can be guide found here
Posted on May 16, 2009
My toilet worked fine yesterday. However, over night, the water in the bowl backed up and overflowed without anyone flushing the toilet. The water is clear. I don't understand what is causing this...
Check that the black float ball isnt hanging up on anything under the cover if it stops and hangs up on something the valve will continue to fill the tank and water willoverflow cause it wont shut off.
Apr 08, 2014 | Kohler Home
I have kenmore front load dryer. wont do anything when you turn it on. was working fine then just stopped. is getting power. what could cause this?
check thermal fuse located in back panel. make sure power is unplugged before removing cover. thermal fuse is located near exhaust and it's coated with white plastic with 2 leads sticking out. with volt meter check for continuity, no continuity must replace thermal fuse, it cannot be reset.p.s. remove wires from fuse to get accurate reading.
rwpfn@aol.com
Sep 01, 2010 | Kenmore 63942 Dryer
Dryer wont do anything. The circuit breaker is good, there is power at the outlet. when you close the door and set the timer and push the start button, it wont tumble or anything.
Check continuity through the start button WITH THE POWER OFF. A cheap ohm meter should show a reading through the switch when it is pressed. If that checks good, use the same meter to read from the switch through the start coil of the motor. You should see something around 4 to 10 ohms. No reading, then check the connectors that they are tight.
It is rare that the start coil goes bad because it is only used on start.
Dec 20, 2009 | Cell Phones
The power light blinks, reads open tray/close tray . . .
it sounds like your dvd drive is dead if its still under warranty you should just send it back to microsoft the only other thing you could do is buy a replacement dvd drive and put it in yourself but only do that if microsoft wont take it or you'll void your warranty
Aug 25, 2009 | Microsoft Xbox 360 Console
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Message says cartridge error 1203 and it wont
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
Feb 23, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Stanton C.314 CD tray wont open
You can replace the cd drive by ordering another one from American DJ online.Give them the model number and replace about three multiple connectors in the same order you have the bad one. That will fix your problem.
Jan 02, 2009 | Pioneer CDJ-800 Turntable
Help my computer wont start if I close my lid ....
It sounds to me that there might be a lose connection somewhere. The first thing to do is make sure that all cables are securely fastened.
When you say that your computer won't start when you put the cover back on and lay it on it's side does it respond at all when you hit the power button? Lights, anything displayed on the monitor, fan noise, etc.? Also when you leave the cover off is the computer laid on it's side like when the cover is on? does it work laying on it's side with the cover off?
MO
Jul 13, 2008 | Acer Veriton 3600GT PC Desktop
Psp wont load any games or do anything bdoes come on to menu
Simply dead laser , search on ebay for the part and look for guides on google or service it to sony
Dec 06, 2007 | Sony PlayStation Portable (PSP) Console
Brother IntelliFax-2820 Laser Fax Logo
139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
