Question about KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher does not clean dishes and leaves spots on everything!!
We bought this a year ago and have tried various liquid and powder detergents and are unable to get dishes, glasses, silverware clean and free of spots. Even the door on the dishwasher has a spotty residue of build up on it.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water that is leaving the spots. There is a fantastic product out called the dishasher filtration system. It filters the water going into your dishwasher and works amazing. It is very affordable and very easy to install. You can get it at www.dishwasherfilter.com.
Posted on Mar 14, 2009
    President:
  • 2,976 Answers
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Posted on Mar 04, 2009
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The dishes do not rinse properly--despite rinse
run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
turn the rinse aid down to about half way.
also check the phosphours content of you washing agent.
there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
reduce the amount of soap a little.does not matter if it is liquid or powder.
once every three months you need to run cleaner through the machine.
last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
Jun 09, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishwasher doesn't wash dishes right
The solenoid that opens the detergent door may have had water leak into it. Remove the inner panel from the main door, remove the solenoid mechanism and it's core. With the core out, clean the solenoid interior and the core surface with hot water. The core should fall out of the solenoid by gravity if it is clean. DO NOT OIL THE CORE OR SOLENOID. If there are signs of water entry to the solenoid, check the detergent dispenser seal for damage. Try using a tab type of detergent rather than liquid or powder. Make sure the release mechanism is clean as well. Hope this repairs your problem!
Dec 29, 2009 | Frigidaire FDB1050REM Dishwasher
My dishwasher has left white chalky residue on all dishes and i have tried several times but it dosent go away
the problem is hard water. there is a product at www.dishwasherfilter.com that filters out these hard minerals that cause those spots and leaves your dishes crystal clear every time. it is very affordable and has a money back guarantee. you will love this product and your dishes again.
Jul 16, 2009 | KitchenAid Dishwashers
Dishwasher gas started leaving water spots on glasses.
I had exactly the problem you describe in my < year old water-conserving LG dishwasher. What I found was that (to conserve $$) I had bought ultra-cheap, generic detergent powder.
As soon as I switched back to a brand name detergent powder (Electrosol or Cascade) my problem gone.
Try that and post back here if this does not solve your problem. OK?
Good Luck!
May 03, 2009 | Dishwashers
White film inside the dishwasher and on dishes
Usa a liquid detergent and rinse agent. Make sure your water is above 120 degrees. If you are a hard water area, use a detergent containing a water softener.
Mar 25, 2009 | Siemens 24 in. SL34A006UC Built-in...
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
My dishes comes out still dirty
I put a bottle of CLR in the dishwasher and I did a wash without any dishes. Repeat if needed.
Aug 18, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
925 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
