Question about Microsoft Windows Vista Ultimate Edition
On running cd error comes out that class not registered in MS vista
  • 86 Answers
Your vista cd not registered . So you can visit internet ,go to microsoft.com and download vista ultimate edition.
Posted on Mar 04, 2009
MS vista and MS office 2007 installation
You install disk is corrupt (probably from a scratch on the disk), you can download a new copy to burn, making sure it passes the MD5 checksum after download is complete (and use your key during installation).
Jun 28, 2013 | Dell Computers & Internet
Windows xp: class not registered
Normally ,windows give this error when some .dll file is missing...
I think better solution is to repair you windows XP using installation disk.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
Aug 28, 2012 | Microsoft Windows XP Professional x64...
Iv tryed most things. my acer aspire 7520 laptop has lost the dvd/cd player from the device manager so it will not work it is connected and it starts up.but no picture or sound.
You need to reset the hi and lo filters for the device, as this is caused by a registry error or corruption
Close all open programs
Click on Start
Click Run
Type REGEDIT and press Enter
Vista doesn't come with the run command enabled so just type REGEDIT in the search bar above Start..
Click on the plus signs (+) next to the following folders to open them.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
(looks like same file name for XP and Vista?)
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Jul 18, 2011 | Acer Aspire 7520-5757 Notebook
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
From where i can down load MS OFFICE WORD FOR VISTA
if you have ms office installed on your pc you can access the ms office word through "Start>All Programs>MS Office>Ms office word" you can also try to launch it using Run. Click Start > Run and type winword
if cannot found error displays you probably not installed ms office. better purchase and install it then.
Jul 29, 2010 | Microsoft Windows Vista Ultimate Edition
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
LifeCam 1.1
Go to MS site and find the upgrade driver to this camera for Vista OP SYS
Jul 27, 2009 | Microsoft LifeCam VX-3000 Web Camera
Sharp XE-A41S - Customer Support Tool Run-time error '75':
you have to run the program as administrator. left click on program icon to bring up menu
Apr 07, 2009 | Sharp XE-A404 PC Desktop
CODE 10 ERROR
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Mar 30, 2009 | Samsung Super-WriteMaster SH-S183L Burner
Microsoft Windows Vista Ultimate Edition Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
