Question about Gateway FPD2275W LCD Monitor
Gateway 2" monitor won't display
My Gateway FRD22" widescreen monitor won't display. Was working fine and then one day I moved the mouse to disengage te screen saver and the screen faded to black . The"On" switch won't stay on, either. Upon boot up it is"on" then goes to hybernate and then to amber or "sleep" mode. I have reconneted an older monitor to the computer and haveful display, do it is not the video card or connections. The 22" screen is operable, because is diplays the Gateway logo troughout boot up. It just won't disply anything else after boot. No desktop display, no nothing. Briefly will, on occassion, show desktop, then shuts down after about 5 seconds. Any help?
  • 558 Answers
Blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Posted on Mar 22, 2009
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Windows XP on my Gateway PC will not accept Viewsonic Widescreen VA1912wSeries . My HP PC broke & I moved the montor to the Gateway. The HP had the same Windows XP system.
Reboot the computer into safemode. to do this tap F8 after the logo screen for gateway goes away. select Safe Mode.
Right click the desktop and click properties. in this window click settings. change the resolution to 1024x768.
click the advanced button. click monitor tab then set the screen refresh rate to 60 hertz.
if the monitor is compatible it will be able to be displayed. else try 1440x900 and 60Hertz for the settings
Feb 12, 2010 | ViewSonic VX2035WM LCD Monitor
Need to know how to adjust my Acer x223w screen. Can i be done with the mouse?
Yes you can adjust the screen .For that go display property in start->controlpanel.
Then set scree resolution to 1024*768 then apply and ok.
Then display is fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 30, 2010 | Acer X223WB 22" WIDESCREEN LCD Monitor
Gateway Monitor FPD2485W
posibly a burnt out CCFL light , more likely an overloaded or burnt out CCFL power supply
JOAT
Oct 16, 2009 | Computers & Internet
How do i getr the creen out of analog power save
Usually hitting a button on the keyboard or moving the mouse works.
If it is really a problem go into your display settings through the control panel, access the power options and stop your monitor from going into powersave mode.
Sep 27, 2009 | LG 19" Widescreen Flat Panel LCD Monitor
Hd display gateway monitor is working but has no signal
Hi
If this is still under warranty, then Gateway (MPC) can repair this. Probably you homeowners insurance will pay for it. Make sure that the monitor data cable is plugged in correctly. Whenever we have storm my wife unplugs all the cables on the computer. Sometimes when we reconnect they get plugged into an inactive port, thus no pic. If none of these help then please contact me at micromend@live.com and we can discuss a repair plan.
Thanks
Jun 20, 2009 | Computers & Internet
Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Screen
Is this an inverter issue with the display? Is it worth fixing.
Yes, and yes.
If it is still under warranty have Gateway fix it.
If not
Go on Ebay and you may find the part cheap.
Dec 23, 2007 | Gateway MX3215 Notebook
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Gateway FPD2275W LCD Monitor Logo
269 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
