Question about Sanyo DP32746 32 in. LCD Television
Message says, "No signal."
I bought a Sanyo TV before digital broadcasting came in. I got Comcast Cable, but I would like to get away from the monthly charge, because I am on a fixed income. I bought a TV converter box and found out I needed an inside TV antenna to hook up to the converter box. I did all of this, and it still does not work.
HELP!! ANY SUGGESTIONS?
I did what Clark said, Antenna to Converter, converter to TV and put TV on channel 3; is that right? I now get a message that says, "No signal."
  • terrymccaul May 26, 2009
    no signal when try to retune i can only get aps tuner cannot get my freeview back.
  • 360 Answers
Try the tv on ch 4 in case the converter box outputs on that channel. let me know what happens and we can get this working
Posted on Mar 04, 2009
3 Suggested Answers
  • 71 Answers
SOURCE: Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Posted on Mar 05, 2009
  • 71 Answers
SOURCE: Sanyo TV, older model, TV converter box, terk inside antenna
no need of a coneverter box.
My 26" LCD HD tv
The tv have an intermittent shutdown,ur tv causes are by the board that called the main logic Tuner signal board.That the board where the tv incomming broadcasting signal cable wire plug into it.This tv it is under a year old,ur tv still under warrenty.Call Sanyo tv Corporation.Take ur tv warrenty repair or tries take the tv back where u bought it.Tries trade it in for another one.
Sep 20, 2011 | Sanyo DP46849 46 in. HDTV
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
I bought a Samsung 22"
This tv have problems with it tv Tuner signal board.That the board,where it take the incomming broadcasting signal cable and external devices inputs into it.Tv is still less than a year old,call for Samsung for a warrenty repair.Out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbuish tv Tuner signal board for the replacement.
Jan 30, 2011 | Televison & Video
I'm wanting to know if this TV is one that is Digital or analog? Will I need to buy a converter box for it if it isn't hooked up to cable or direct TV? I believe it was purchased in 2006.
No.It is a digital tv.Just require a good digital antenna for a better and a longer ranges for the tvs broadcasting stations incommming signals.After a digital antenna is hook up.When u go in to the tv menu go to Setup.go down to CH. pick AIR and enter and tv should be automatically be scanning for DTV free air broadcasting tvs stations.
Dec 05, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
I have a Sanyo DP37647, the red color seams to have disappeared. We've adjusted manually, but can't get the red color back to the screen. Red's are now showing as black.
Tries the broadcasting incomming signal cable,with another tv connected to see,if can get the red color,if no than,the imcomming the broadcasting cable it the problems.If yes,ur tv have a Tuner board problems,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 25, 2010 | Sanyo DP37647 37 in. LCD TV
Tried to connect Sharp 19" LCD TV (purchased on 2008) up to new Comcast Digital TV Adapter. Screen sez "Failed to receive broadcast". The DTA works on other TVs. Is it the TV settings that need to be...
I had the same problem when I got one of these a few months back. Once get it all hooked up give comcast a call at: 1-800-266-2278(or 1800comcast) they will have to update some codes and reset it to get it up and running.
Should take less than 5 min's once you get a rep. on the phone.
If you need any further help give me message in the comments
Mar 18, 2010 | Sharp 19 in. LCD HDTV
What is the difference between HRC, IRC, Std and Auto when scanning channels - I hate the new digital TV world - it has total confused things - I have comcast cable
Usually standard broadcast is is the default setting,some other cable company use HRC and URC, these are ways to transmit or deliver their signal trough cable wire,ask comcast cable for their transmission type.
Aug 30, 2009 | TruTech PM1919BXA1 19 in. LCD TV
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Just bought new 32" sanyo model dp32648. Can't get the picture or
If this problem is happening on a regular TV channel and does not appear when watching an HD channel or while watching a DVD then most likely you have no problem at all. What you are seeing is actually the LOW Definition signal sent for regular TV programming that used to look pretty good on a small tube style screen but now is enlarged on a screen capable of incredible accuracy and is displaying all of the poor quality attributes of standard definition TV.
Feb 25, 2009 | Sanyo DP32648 32 in. LCD TV
Sanyo DP32746 32 in. LCD Television Logo
215 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
