Question about Kicker Solo-Baric L5 Car Subwoofer
My l5 is taking a while to start working after
My l5 is taking a while to start working after music starts and some times i have to press pn the ceter to get ir going
Get a new amplifier!
Posted on Mar 04, 2009
HI our Bowflex series 3 treadmill is giving us a continued Err L5 code when trying to use our machine. We bought it used so do NOT have ant trouble shooting instructions. Any advice?
Hi There, L5 error should refer to the "LS" error which looks up to a speed problem. When you start the machine up, it boots fine and then when you press start or go is says err ls ? If the walking belt doesn't move at all when you try to start it, listen for a "Click" on that lower board when start is pressed..... If the walking belt moves for a second and then stops and the console says err ls, then you may have a speed sensor problem. These control boards are repaired by Jatinah Electronics who can be found with a google search. Good Luck!
Dec 13, 2016 | Bowflex Exercise & Fitness
My landice L7 pro Trainer is not working when you press the start button the motor jolts a little the L5 shows is the display screen
It needs a lower board, does your machine have a life time warranty? Part should be covered just not the labor.
Apr 02, 2015 | Landice Exercise & Fitness
TREADCLIMBER tc5000 error code L5
Step 1:
see the comment. and fix it. Run the software calibration.
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board. Refer to the proper flowchart.
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 06, 2013 | Bowflex TreadClimber TC5000
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The washer stops working and the light flashes L5
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I'm having trouble with my music play er pls. help !!! :(
Hello i hope u 'll be fine.... thanks for using fixya.
This problem is usually occur when music player don't load data of phone or memory card itself
  • Turn on your cell, when it 'll be on, Starting music player it 'll take some time to refresh
  • Now do in the options of music player
  • Second option 'll be music library open it
  • Go down there 'll be a last option Update Library,Press ok, it 'll take some time and hope it 'll load all your music and all music files 'll show in track list.
Enjoy
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if if it is helpful
THANKS
Mar 01, 2010 | Nokia 3110 Cellular Phone
L5 show in display and won't work in calypso washer
ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kicker Solo-Baric L5 Car Subwoofer Logo
73 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
