Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Speratice printing I think the drum or print head may need to be cleaned,but cant get to it. When I am printing about every sixth line or so is not printing
  • 684 Answers
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer.
Good Luck
Posted on Mar 04, 2009
Got a ir2225 canon copier printing some white lines, anyone know why?
quite possibly you might need to do a head clean or a re-alignment of your printer.
Dec 12, 2014 | Canon Office Equipment & Supplies
Printer prints black lines across the page
Clean printer head with clean damp lint free cloth see if that works if not, print heads do wear out sadly.
Jul 21, 2014 | HP LaserJet 1020 Printer
My Oki C310dn printer prints lines through everything.
You need to do s head clean.
This could take 2 or 3 goes but should fix it you will find head clean in the maintenance settings.
It eats the ink so only do as you need.
let me know how it goes.
Regards Craig
Feb 03, 2018 | OKI C Office Equipment & Supplies
Samsung printer ml 1640 printing lines with the text all over pages
have your printer calibrated and have the printer heads cleaned, if this does not fix it you need to take your printer into a tech center to have a professional take a closer look
Sep 05, 2012 | Samsung Office Equipment & Supplies
The color is not printing correctly. Things are coming out mostly pink or yellow. I tried the MAINTENANCE tab. The nozzle check showed that the top section (PGBK) looked good. The second section (C)...
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
http://compare.ebay.com/like/330643273134?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
Nov 27, 2011 | Canon MP830 All-In-One Printer
Paper stuck under the print head container
pls clean ur drum with tissue paper or soft cloth and then try once
even after if the same thing happens change the drum or catridge
Sep 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
I have a Canon i865 printer which was printing stripey. I cleaned the print head but then it didn't want to work at all. I bought a new print head but it's not working at all still. Plug in, get 10 amber/...
The stripes on prints is usually caused by some residual particles on the drum which indicates that the drum is not properly cleaned. Try cleaning the drum(Be careful not to damage the drum). I have psted the link which guides you through the drum cleaning procedure below. Follow it carefully and there should be no problems.
http://www.instructables.com/id/How_to_clean_the_printer_drum_cartridge/
If it doesn't work may be its time for a replacement drum. Contact canon for a replacement
Dec 07, 2008 | Canon Office Equipment & Supplies
HP Laser Jet 2420d
drum cartdrige or fuser see for more info t isolate fault refer to
http://www.fixya.com/support/t248646-black_streak_one_side
Nov 08, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
