Question about KitchenAid KCMS145J Microwave Oven
TIMER COUNTS DOWN, MICROWAVE DOES NOT TURN ON
LIGHT TURNS ON, COUNT DOWN IS ON, MICROWAVE DOES NOT COOK AND TURN TABLE DOES NOT TURN.
  • 1 more comment
  • Austin8181 Mar 04, 2009
    Same as above. Light turns on, turntable turns, timer counts down, stops cooking after 1-2 minutes -.-
  • Anonymous Mar 13, 2009
    serial#fgm2610781
  • Len Falk
    Len Falk May 11, 2010
    Do you have the make and model of the unit?
  • KitchenAid Master
  • 9,030 Answers
To actons2 - This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Note to Austin8181 - Your problem is not quite the same.
Please report as a separate request and of course please include your brand and model number.
Posted on Mar 06, 2009
Why does Microwave count down but will not run?
Sounds like a door switch is not closing; either primary or secondary. You could have either a bad switch, or the latch assembly is not aligned properly.
Aug 31, 2014 | Emerson Black Microwave Oven
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
When I go to cook something, there is barely any noise and oven doesn't cook. Plate turns slowly and timer counts down, but its not cooking. Also, light went out
I think it is time for a different microwave. Sounds like you may have some bad or worn capacitors, circuit board, or relays. The system will need to be fully tested to determine cause
Aug 06, 2009 | Microwave Ovens
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
1,041 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
