Question about Whirlpool LSB6200KQ Top Load Washer
I have a Whirlpool washer that sometimes spins as it drains, which it is not supposed to? I am not exactly sure where to look. HELP.
  • Whirlpool Master
  • 8,220 Answers
The washer has what is called a neutral pack, this washer is supposed to allow the pump to remove the water before spinning the clothes. The original ones did it. So it really does not matter if it does that or not. The real reason is from not enough use. So the more you wash the better it will get or it will be costly to repair the washer. I would not worry about it.
Posted on Mar 04, 2009
Washing machine isnt' draining nor spinning.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Draining or spinning will not work
i think you have something stuck in the pump.a sock or something have some one check it for you.im pretty sure youll find something in the pump though
Jan 29, 2009 | Whirlpool LSB6200KQ Top Load Washer
Clothes still wet after final spin
Possible timer or drain problems.. ok.. when your washer is in rise.. before it goes into final spin.. it stop agitating, then drain water for about a minute or two.. listen to see if stop drain for a sec, then began to spin... when it come to draining.. make sure that you hear all the water flow out of your washer.. sometimes when you have a slow drain.. that can do it too.. but the first possible is likely.. good luck
Jan 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Trying to fix belt
this machine does not have a belt, sounds like your coupling is broken.it will still drain with a broken coupling.
Oct 13, 2008 | Whirlpool LSR5132PQ Top Load Washer
Caylpso washer
sounds like a motor controller issue i have the manual post your email if you want it
Jun 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
104 people viewed this question
Dan Webster
Dan Webster
Sal De
