Question about Refrigerators
My dometic RM 7732 elite side by side has apparently lost the cooling element and I am advised to replace it with a new one. Any models out there that would replace it, as space on this unit is limited for replacement size.
  • Jerry Shannon May 11, 2010
    The replacement is NDM1292. Does it have an ice maker? I can supply you with on. There are several 1292 models.
5 Suggested Answers
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
tunmun
  • 413 Answers
SOURCE: dometic rm2611 not restart after cooling box normally, then warmi
Your fridge is working against outside air tempurature and any solar heating effect. To maximise the operation of your fridge allways try to park the unit so the fridge side will be in the shade. Do you have a fan to create the air circulation in the back of the fridge? There are kits available for this. I use a recovered converter fan and have it set up in the bottom of the fridge cavity below the coils and blowing straight up. This helps a lot. The kits normally come with a 80 degree F temp switch, I have a leftover toggel from some where for mine. I don't think your fridge is the problem. I don't think a new one will fix it. Your best bet is to do the kind of thing I have above and it should work better. Hopefully good enough. Good Luck
Posted on May 11, 2009
SOURCE: busted solenoid for icemaker
got info free
Posted on May 26, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 30 Answers
SOURCE: DOMETIC RM 123E PILOT LIGHT LIGHTING BUT WONT STAY
try fitting a new thermal coupler
Posted on Jul 23, 2009
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Dometic refrigerator troubleshooting rm 3662,
Hi, It is more then likely the heating element or a fuse in the electronic board located on the rear of the refrigerator. The heating element is located on the right hand side looking at the rear of the refrigerator. It is the probe like item that protrudes from the duct work with two black wires attached. You must disconnect the wires from the board then take the door off of the duct work, the the heating element will slide upwards to remove it. Please feel free to contact us 1-888-782-6665
ArctiCold Refrigeration We keep it cold
Aug 17, 2014 | Dometic Refrigerators
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
I have a Dometic RV refrigerator Model RM 2652. After starting the unit up it cuts back off in a minutes. Checked and found out not getting power to the unit. When I plugged straight in to another outlet...
On the back side of the refrigerator to the right you will see a couple of wires going into a metal rod that is bent. That is the electric heating element. Grasp hold of the metal/rubber booted end and see if you can move it from side to side. If it will not move then that typically means that the heating element has failed and has welded to the cooling unit. When this happened it not only could cause a short but could also rupture the cooling unit causing a loss of the hydrogen/ammonia mixture. If they are moveable then you may have a bad circuit board that is causing the unit to shut down to protect the other components.
Oct 15, 2013 | Dometic RM2652 Refrigerator
My Dometic refrigerator model # Rm2652 does not cool anymore. The element heats up on both gas and electricity. I noticed an amonia smell and there is yellow matter at the bottom of the stack where the...
Your cooling unit is done, and will need replacement. I will urge you to take down model and serial number and go to their site, or call Dometic , ( www.dometicusa.com) 1-800-544-4881, and inquire whether your unit falls into the recall on some of those models. You may end up with a new cooling unit, free of charge.
May 23, 2011 | Dometic RM2652 Refrigerator
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
816 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
