Question about Toshiba e-STUDIO 4511 Printer
Printer won't print properly
The PCL6 drivers work but they are black and white only. When I installed the PCL5 drivers it will only print black and white and whatever should be in color comes out as black boxes running off the page. I need color! My test pages are all screwed up. I am running windows xp and the driver is the correct driver. Thanks
  • 523 Answers
The problem is in the driver, try to install the GDI driver or post script , i think you can change this from driver setting, and if your printing color pdf files and it gives you this, this means the driver setting is wrong, try color microsoft word test and check if it gives you the same result.
Best Regards
Posted on Mar 04, 2009
Cant print in color with e studio 281c I can copy in color
The 281c can be set to print to black only as a cost saving measure. The printer control panel is accessed through your browser (using the IP address of the printer) and the setting is made there. You should be able to override this through the printer properties in windows, but I have found that the PCL5 driver worked to switch between B/W and colour, while the PCL6 driver did not. So, for me the easy solution was to install the PCL5 driver and use that.
Apr 02, 2014 | Toshiba E-studio 281c Copier
Can't find sharp ar-bc320 driver for 64bit, there's only PCL5 driver which won't work, we need PCL6 driver for this model.
Sharp does not natively support or provide a PCL6 driver for this device. That being said, another possible workaround to provide you with a PCL6 driver for this is to try the HP Universal Print Driver for Windows PCL6 x64bit. This driver simply prints direct to the IP address that the printer uses on the network. You may sacrifice a few special features of the device using this driver, but I've had excellent success with it and recommend trying it.
Here's a link to the driver:
http://hp.driversdown.com/hp-drivers-download/HP-Universal-Print-Driver-for-Windows-PCL6-x64_18967.shtml
Hope this helps!
Jun 20, 2011 | Computers & Internet
I am getting a pcl xl error I/O Subsystem: InputReadError Error: ReadImage Operator: ReadImage Position : 14 Please help this only happens when tyring to print a PDF from Adobe 9.
You didn't say what kind of printer you have.
Sounds like a driver problem.
Go to the manufacturers web site and download the latest drivers for your printer.
If you were using the PCL6 driver, try installing the PCL5 driver. If you were using the PCL5, try using the PCL6.
Mar 08, 2011 | Office Equipment & Supplies
Can't print to DP8020e from WinServ 2008 R2 with PCL6 nor PS drivers. Output goes from system queues right and then isn't priting without any errors comunicated from printer. Printing from 2003 with PCL5...
uninstall the driver and reinstall back the driver or make sure the pc is properly connected to the copier.one you can see the icon of the printer on the pc means it due to print
Feb 07, 2011 | Panasonic DP-8020E Black and White Copier
Printer 2550n will not print in color, only in black and white, since I installed Windows 7. The networked iMAC (Leopard) still prints in color on the same printer
Check your driver. It is listed on your printer properties screen. Make sure the driver is not the PCL6 driver. This is the only driver that is Black and White only print. This is about the only cause of a color printer that only prints in B&W. If it is PCL6 just dowload and onstall the PCL5C driver.
Good Luck
Aug 21, 2010 | HP LaserJet 2550n Printer
Want to set default output as black only and not color for computers connected to this printer. How do I do it?
Hello get, lets give this a shot.First I need to know what operating system you are using .Next I need to know if the print driver was installed on each individual workstation or if it is only installed on the server and being "shared".And which version print driver you are using(UFR,PCL5,PCL6). But a shotgun answer is to click START,then PRINTERS FAXES.Then right click on the IR3220 printer.Go to PROPERTIES.The print driver will now be in front of you.Click PRINTING PREFERENCES.After you do so,you will see a page with many options.Across the top of page wll be several tabs and on the far right will be QUALITY.Select it, and toward the center of the of the page you will see COLOR MODE.There you will have a drop down menu which allows you to select black white only.Select it and then hit APPLY and then OK. Tada :-) Have a great day
May 01, 2010 | Canon imageRUNNER C3200 Copier
Prints gibberish when a multi-page color document is printed
This could be a driver issue. Without knowing exactly how your printer is connected to the network I'm making a rough guess here.
There is a Universal HP Printer driver that could be tried as well as the PCL5, PCL6 and Post Script drivers.
I've had issues with the PCL6 drivers before doing this and I usually install the PCL5 drivers instead.
Jun 21, 2009 | HP 4700N Color Q7492AABA Laser Printer
Does PCL6 support duplex printing?
This is gona be a helpful website for you
http://search.lexmark.com/printer/US/en/13D0000
Jun 27, 2008 | Lexmark T644 Laser Printer
HP Laserjet 4250 PCL6 prints only one page
Vista??? will be a driver issue, are cd drivers correct for your system?
Goto canon web download correct driver, delete old reinstall, most operating system will have this driver standard.
doubt printer problem prove by doing test prints via printers menu.
Nov 09, 2007 | HP 4250 Monochrome LaserJet Printer
Toshiba e-STUDIO 4511 Printer Logo
277 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
