Question about Palm Treo 755p Smartphone
Tried the hard reset for Palm Treo 755p. It asks to erase data. I say yes. And then nothing else happens. Anyone try anything else? Is the phone done?
You HAVE to puch the upper part of the button and not the center to clear them.
Posted on May 27, 2009
  • marian465 May 27, 2009
    President:
  • 1,223 Answers
Yes it is hard reset already it is the normal behavior
pls rate me fixya for the help i provided or tell me ur issue in detail if u want anything else
Posted on Mar 04, 2009
  • Shoaib Rais
    Shoaib Rais May 28, 2009
    PLS ENCOURAGE US TO HELP OTHERS !
    I was trying to help and it is Free as u know i am not getting any
    financial gain from helping u, the only thing i need is good rating, so
    kindly update ur rating for the solution and more questions are welcome
    Regards
    Zohail
"access powered" after the "palm screen"...keeps doing the same thing over and over
you have to hardreset your phone it will wipeout your all the data. but it will work
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p is hard reset.
Jun 22, 2010 | Palm Treo 755p Smartphone
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
How do you hard reset on palm treo 755
Hard resets on a 755p are described in the user's guide as removing the battery (with the phone off, and screen off), and then pressing the Navigator-UP button and holding until you insert the battery again, and you see the Orangle PALM logo displayed, where you can release your Nav-UP button. This does not work.
You need to hold down on the red power button, until the Orangle PLAM logo shows up, release it, and you will see a question like "do you want erase all of your data?" , press the Nav-UP button, and it will now do a clean hard reset.
Now, on the backup folder.
If you do not change user-names, and your PALM Hotsync setting for 'Backup' is set to 'Desktop overwrites handheld' you will get everything back when you HotSync. Therefore, if you delete the problem App's from your Backup folder (ie C:\palm\755p\backup, where 755p = your HotSync name) and you change to the settings on 'Backup' to 'Desktop overwrites Handheld' - then when you hotsync, you'll get the app's you want back, and not the ones you do not.
I hope this makes sense.
Sep 18, 2009 | Palm Treo 755p Smartphone
My palm treo 755p
Dhorner64 is incorrect. Your phone is not fried if you are in a restart loop. You need to do a "warm reset" which will not erase data. It is the equivalent of doing a safe boot in Windows. Remove the battery from your 755p, then put it back while holding the up button on the 5-way. Hold the up button as the phone starts. I had to do this frequently, then run the DataViz Tech app, which is available free from DataViz, to fix their prefs file, which was the source of my crashes. The problem was solved by upgrading to Docs2go v11. I was reluctant to pay to upgrade a crashing app, but the upgrade ended the frequent crashes. I have not had a couple resets since upgrading Docs2go, and no reset loops.
Nov 23, 2008 | Palm Treo 755p Smartphone
Palm 755P Freezes
Well, thank God I had done a recent Hot sync! I found out how to do a hard reset by holding down the power button while reinserting the battery then letting the button go and the system will ask if you want to erase all data? I put yes! Then it erases all my data and restarts the phone. I had to plug the phone in to be recharged because the looping ultimately drains the battery. Then, I plugged in the Hot sync cable and pushed the button to start the sync and ta da! back to its working state! Yippee! Do it! It's easy! Just make sure to hot sync often so your info stays current!
Aug 26, 2008 | Palm Treo 755p Smartphone
Treo 755p screen freeze
Sir U ve to Flash ur phone: its look like to install a new OS in it .u need a tool called box phone its expensive just repairman use it. so seek for one or use our ones by using this repair service and put ur zip code of area.
rate me plz^^
Aug 05, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
TREO 650 Phone won't work
I experienced the same problem while traveling this weekend. The green phone button and anything associated to the phone all of a sudden stopped working. No call out and none in. I hotsync'd and also did a "hard reset" except I said yes and then went in and hotsync'd again. Phone now works again and all data is back
May 04, 2008 | Palm Treo 650 Handheld
Palm treo reset
You want to perform what is called a "Hard Reset"
It's pretty easy. You hold the power button while you push the reset button on the back. The treo will ask you if you want to erase all the data.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, hold both for a few seconds, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Here is a explaining what I just said above:
    http://mytreo.net/archives/2004/05/hard-reset-the-treo-600.html
    Sep 22, 2007 | Palm Treo 600 Handheld
    Palm Treo 755p Smartphone Logo
    456 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    ray gallant
    Raj Patel
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
