Rank: Guru
Rating: 88%, 350 votes
Hi there and welcome to FixYa.
Check your card, there is a little switch on the side of the card. One side says locked and the other side says unlocked. Move the switch to unlocked and put it back in and try it again.
Rob
Comments:
Mar 05, 2009
- Ok then, have you formated the card in the camera using the menu? That should fix it. If it doesn't let me know. If it does, then you can change the rating to a FixYa.
Rob
Mar 07, 2009
- What model of Nikon are you using?Mar 07, 2009
- Ok, so you have:
Turned the Mode Dial to Setup.
Then use the 4 way directional button to scroll down to format the memory card.
Then choose Format.
Then scroll right.
Then scroll up or down to Format.
Then press the ok button. It will say formatting.
Then your done. This will format your SD card if the switch on the card is unlocked.
Try it and let me know how it goes.
RobMar 29, 2009
- Ok, here is your problem. Your trying to use a card that's too big for your camera. Try a smaller card and you will see a difference.
Rob
