2001 Isuzu Rodeo Logo
Aaron Burns Posted on Mar 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a "computer flash update" for my 2001 isuzu rodeo ls 3.2l (v-6)
I am at my witts end with finding any solutions for getting my car smogged. That check engine light won't seem to stay off. Computer codes that keep popping up are: P1120, & P0401. Money is somewhat been an issue, but I just don't remember ever buying a second house, if u know what I mean! Please, car is our travel means. Single dad, 3 young kids, mom still nowhere to be located(her choice). Aaron
Bill Boyd
Level 3:
Top Expert:
  • Isuzu Master 53,816 Answers
  • Posted on Mar 31, 2013
Bill Boyd
Isuzu Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949745
Points
172802
Code p1120 refers tothrottle position sensor1--circuit malfunction---causes ---wiring open cuircuit--/short circuit to ground/short circuit to positive---throttlecontrol unit---ECM
code p0401 refers to exhaust gas recirculation(EGR) valve system---insufficient flow detected. ---causes hose leak/blockage--basic setting not carried out (if applicable)---wiring---EGR valve---EGR solenoid----ECM. I would replace the EGR valve for starters Get unit from the wreckers. You may have to have the CPu reset with a code reader tool
Anonymous
Level 3:
  • Master 1,010 Answers
Anonymous
Master
Level 3:
Answers
1010
Questions
Helped
247233
Points
3078
Check the TPS and EGR
4 Related Answers
Anonymous
  • 396 Answers
  • Posted on Jul 21, 2009
SOURCE: 2001 Isuzu Rodeo Check Engine Light flashes when accelerating.
I would change the trans flter, trans fluid, and have the linkage on the trans adjusted.
Anonymous
  • 9 Answers
  • Posted on Jun 11, 2009
SOURCE: Engine light on- code 44 came up for 2001 Isuzu rodeo
Fuel air metering.....
Anonymous
  • Posted on Apr 02, 2010
SOURCE: 2000 Isuzu Rodeo LS ~ check engine & reduced power lights
Do you know the OBDII codes? I just had to replace my Mass Air Flow sensor, it seems to have fixed my problems. But check the error codes.
honeymokey
honeymokey
  • 3113 Answers
  • Posted on May 14, 2010
SOURCE: code P0401 on my 99 isuzu rodeo
egr soleniod
2001 Isuzu Rodeo LS 3.2 DOHC 24 valve - V6.
camshaft position Sensor location???
Isuzu SUV Forum https://www.planetisuzoo.com > threads > camshaft-po...
Jun 23, 2009 - It is located on the inside surface of the front of right cyl head. 2000 Rodeo LS (stock). 78 T/A (far ...
SOLVED: Where to locate the camshaft sensor on a isuzu
Fixya https://www.fixya.com > ... > Isuzu > Rodeo
1 answer
It's on the inside of the cylinder head at the rear of the engine. Will be hard to see it because the intake plenum hides it. where to locate the camshaft ...
Doesn't include: LS ‎' Must include: LS
Where is the camshaft position sensor in my 2002 Isuzu ...
JustAnswer https://www.justanswer.com > Car Questions
May 13, 2020 - My son is a mechanic and the Haynes manual says it's under the lower intake. Need to verify. Share this conversation.
1 answer · Top answer: you are welcome
1helpful
Is 2001 Isuzu Rodeo LS 4wd owner's manual same as 2000 and/or 2002?
Yes, they are basically the same, except for paint color combination and a few other changes in interior.
Other than that, the drive train and engine are the same.
I'll have to see if I can find a PDF online.
It's a 2001 rodeo LS 2×4 v6 3.2 lit motor
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
How to remove accumulator on transmission on Isuzu Rodeo?
Planetisuzoo.com • View topic - Transmission Accumulator Piston Cover
forum.planetisuzoo.com/viewtopic.php?t=38884
Apr 2, 2010 - 20 posts - ‎8 authors Have any of you ever changed the Accumulator Piston Cover on the side of yourtransmission? ... 2001 Isuzu Rodeo LS :: 3.2L V6 Auto 4L30E >> clicky for pics << ... I got the kit, and I even scored the removal tool on eBay. 1991 Trooper Transmission Pan ...
Mar 20, 2012
2000 Rodeo Transmission Fix
Jun 25, 2011
Smoke coming from bottom of Isuzu ...
May 21, 2011
TSB information
Jul 23, 2007
More results from forum.planetisuzoo.com
isuzu rodeo transmission - YouTube
? 1:37
www.youtube.com/watch?v=CyJZQLwnfPY
Sep 3, 2013 - Uploaded by besiratabay
2001 isuzu rodeo transmission problems 2002 isuzu rodeo transmission 1999 isuzu rodeo transmission .
3helpful
2answers
Vacuum hose diagram for 2001 isuzu rodeo
Need a vacuum line diagram for a 2001 isuzu 3.5 engine.
4helpful
2answers
My Isuzu Rodeo LS V6 2001 ran out of gas and now
get under the truck and hit the tank hard with your hand the pump may be stuck a couple good wacks might work
3helpful
2answers
I have code P0401 on a 2001 I SU RODEO V6
You've probably fixed this by now. I had the same problem and it wouldn't pass the smog check. I thought I'd have to replace the EGR valve but now know that would have not solved the problem.
The solution was to remove the EGR valve, plug the rear hole and use some carb cleaner down the other hole. I'd get two cans. I sprayed a bunch of liquid in the hole but it just filled up. Had my wife come out and rev the engine for a bit. Finally, the liquid got sucked into the port and I sprayed an entire can in while she kept the engine RPM up. Bolted the EGR valve back on, took it to the Smog check place and it passed with flying colors.
Need key code to have lost ign. key on 2001 isusu rodeo ls remade at locksmith
Hi:
You need to call your local Isuzu dealer, and have your VIN number handy, as their service department should be able to get your key code from the VIN number
2helpful
2answers
Obd code 1627 ,1999 4 cylinder isuzu rodeo
If P1627 is set when there is a problem with the fuel level sending unit, 100% sure on this problem, replace the fuel level sender in the gas tank, about 2.5 hours, very straight forward job
1helpful
Failed Smog Test - 4 codes for 2001 Isuzu Rodeo
Tune it up and replace the 02 sensor that keeps setting the codes bank 2 sensor 1. Have your oil and filter changed right before you go for a retest to. That will clear up 3 codes P0300, 0155 and 0154. You might have to replace the fuel sending unit to get rid of P0463 but if the gauge works OK I'd leave it alone.
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
