Gateway TB120 moniter will not stay upright it flops down. Mounting seems to move around
  • Anonymous Mar 31, 2009
    I have the same problem.... The moniter does not stay upright. IS there someway I can open it to see if it can be fixed.I v'e only had mine for 8 months...
How do i type while in tablet mode on my gateway tb120?
Use the on-screen keyboard. the system has a touch screen after all.
Mar 25, 2013 | Gateway "TB120 Laptop Core2Duo 1.2Ghz...
A screw came out of my DC28 Animal and now the vacumm head does not stay locked in place when the handle is upright. The head flops around. I have the screw. it has one of those sleeves with a flat edge....
I'm sorry to hear you're having difficulties with your DC28. It's probably best if you get in touch with us directly, so one of our experts can provide the assistance you need. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 25, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
The machine keeps giving me an error message with a diagram showing the foot should be down. It is, but it won't sew anything. I can thread a bobbin, so I know there is power to the machine. Also, when...
that presser foot with that black thing that is just flopping around... well when the presser foot is down that thing should be locked into the side hole. when you have the presser foot up, put it into the side hole, fiddle with it, move it around til you find that hole, then drop the presser foot it should be locked on it now. That T presser foot needs that.
Aug 23, 2010 | Euro-Pro Sewing Machines
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
My Gateway laptop model TB120 hinge is broken. any one knows where i can buy a hinge for this model.
This may help and may not. It seems there are lots of people having the same problem you are. The best way to get a replacement seems to buy a cheap junked out Gateway and use the hinge from it. However I would be very careful doing this because the one you buy may not have a good hinge. As many people there are with these issues I would contact Gateway to see if they had a replacement part and would ask to file an official complaint. In addition here is a number to a laptop repair company, they will help you find the most cost effective way to fix your laptop. They are good I have used them for parts before. 1 (800) 999-4409
Jun 10, 2009 | Gateway Tablets & eReaders
BROKEN HINGE GATEWAY LAPTOP TB120
search "gateway e-155c lcd swivel assembly" on google or any other search engine and you will find the part that you need.
You will need to do your own replacement, but that is the part that will fix your problem
Mar 28, 2009 | Tablets & eReaders
No picture. Yellow light stays on. No blue light !!!
the problem with the CPU might be the graphics card is down
u should check the ram connections....
also check if ur moniter works on other CPU's or not
if not then this might be a problem with the moniter
Oct 25, 2008 | Gateway FPD2185W 21 in. LCD Television
Cleaner Head flopping down
Hi.
This is very common problem & easily put right just go to Dyson UK site They have a help section with pictures that will show you how to fix this.
Chris..
Oct 24, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
