Question about Water Heaters
How do I raise the water temperature on rheemglas 81VH40D water ?
Raise temperature
  • bzmeltzer Mar 04, 2009
    got it. it was behind WAD of insulation that I did not want to disturb when I first saw it. we are set at 125, should be hot enough right?
  • 408 Answers
There should be settings on the thermostats.  Should be a control panel towards the bottom.  It will have a little lever or knob.  It will also have 12345 or A B C or something similar.  Read the manual to find out what the corresponding numbers or letters are in temperature range.
Posted on Mar 04, 2009
  • Shadow1989 Mar 04, 2009
    125 is what I have mine set at.  It is pretty hot.  But depends how much pip you have to go through and how insulated your walls are.  I would check the temperature and wash your hands to see if it is to hot for you or not.
I NEED A RHEEMGLAS HEATING ELEMENT FOR A 50 GALLON WATER HEATER
Heating elements are most all the same. take your old one to your box store of choice and get one same style and wattage. 1500-1500 that sorta thing
Feb 22, 2015 | Water Water Heaters
What kind water heater can replace Rheemglas fury 81vp20s?
what ever kind you want of course gas for gas and electric for electric
Jan 14, 2015 | Water Water Heaters
Water drips from the overflow pipe on top of the electric hot water tank Tank is a RheemGlas
1) Copy following link for troubleshoot and replacement:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Add comment Mar 2013 and say what you discover
Mar 11, 2013 | Water Heaters
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Water temp stays at 160 degrees
Specific type of water heater does not show on web search.
I am guessing you have tank-type electric water heater.
Did you replace both thermostats and test elements?
Element could be cracked, thermostats can stick open, upper thermostat wired incorrectly, wire shorted.
We know that electric power to water heater is good, and circuit breaker is good.
Why is eco is not tripping? Why is TP valve is not leaking?
Copy following links for step-by-step:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jul 21, 2012 | Rheem Water Heaters
I have a 12 gallon rheemglas electric water heater. How do I turn down the temperature. The water is scaldingly too hot
turn off the power,then on the side of the WH there should be a Blue cover take the cover off,if u have gloves u might want to use them because u might have to move a small section of fiberglass out of the way after that u will see a black looking box with a red button in the center below that button on most WH u will find the thermostat use a small screw driver to turn it down Clockwise to turn it up Counter clockwise to turn it down Put fiberglass back in put cover on turn power back on
Mar 31, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For money-saving water heater information:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
How do i raise the temperature from 120 degrees to 125 degrees
You need to use a remote control to raise the temperature from 120 to 125. The part number is N-7649M.
Sep 19, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
No hot water...where is the reset button on the 81vh40d hot water heater by Rheem
the reset is under the top cover, take the screws out and there will be a plastic sheild pull it off DO NOT TOUCH ANY WIRES push the reset button you should here it come on,, if there is any water present do not turn it on but find the source of water and fix or replace the water heater
Jun 07, 2009 | Water Heaters
Water Heaters Logo
554 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
