Question about Moen 103459 Drain Pop-UP Plug
The drain pop up is not long enough to raise the stopper out of the drain openning
  • b1montgomery Mar 04, 2009
    It is a brand new faucet and the adjustment is all the way extended
  • 408 Answers
If you look under the sink, there should be an adjustment for it, that is if this is the stopper that came with the sink.  If it is an aftermarket, make sure you got the right size.
Posted on Mar 04, 2009
  • Shadow1989 Mar 04, 2009
    Disconnect it.  Have someone lift the plunger all the way up.  Push it down about 1/2".  While they are hodling it there, put the stopper int he sink all the way down.  then go underneath and reconnect.
Remove stainless pop up stopper from bathroom sink?
Look on drain tail pipe, in the back you will find a nut that holds a ball with a short piece of rod going into drain and along piece of rod that is connected to the closure rod mounted in the faucet . Remove clip and disconnect long rod and pull long rod down to raise stopper./ Hold stopper and unscrew the nut and remove rod. Pay attention on the position of stopper piece that the short rod in inserted thru.
Nov 22, 2017 | Plumbing
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
How to adjust the height of the pop up stopper
There is a threaded rod in the over flow line. Take the plate off adjust shaft by screwing it out making it longer so the stopper opens more, or screwing it in to make it shorter so it will close the stopper sooner.
Jun 13, 2014 | Kohler K-7161-AF-BN Clearflo 1-1/2"...
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Grohe drain stopper installation
They adjust by twisting them.
Jan 20, 2014 | Plumbing
I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
Pop up raises only partialy, pop up not square in drain
YOU CAN TRY BY ADJUSTING THE ROD ,UNDERNEITH THE SINK ,MUST POP-UP ASSEMBLIES,HAVE A ROD COMING OUT OF THE DRAIN AND A ROD WITH SEVERAL HOLES ON ,IT TO ADJUST HOW FAR YOU CAN PULL THE ROD UP ,WHICH IN TURNS SHOULD MAKE THE STOPPER GO DOWN,ALSO A COMMON PROBLEM IS THERE IS TO MUCH HAIR AND TOOTHPASTE STUCK ON THE STOPPER ITSELF,SO SIMPLY UN SCREW THE NUT, THAT IS HOLDING THE ROD INTO THE DRAIN ,THEY LIFT UP THE STOPPER,THE STOPPER SHOULD NOT BE ABLE TO BE REMOVED WITHOUT TAKING THE NUT AND ROD OUT ,IF SO YOU MIGHT HAVE TO REPLACE THE WHOLE POP-UP ASSEMBLY
Mar 17, 2010 | Plumbing
I removed the plug on my American standard lifetime drain and it won't close now. I can't get it to hold water now. I can't find any diagrams to show how the plug should be configured to help solve the...
You have to take apart the "drain rod" assembly under the sink. There will be a rod with nut on it that goes into the drain near the sink. Take the nut off, drop the stopper in with the eye hole towards the wall and then reinstall the rod through the eye on the stopper and tighten the nut.
Oct 22, 2009 | American Standard Lifetime Drain, White
I installed a new sink and pop up drain assembly. But the drain drains very slow because the stopper does not go high enough. I have tried adjusting the pop up assembly.
make sure that the piece going in to the drain that moves your stopper up and down is all the way in the hole on the bottom of the stopper once that is in hold the rod down so your stop is up then attach it to the piece attached to your rod this should solve your problem good luck
Mar 11, 2009 | Belle Foret Bathroom Sink Faucet -...
Drain pop-up funnction not working
The stopper portion of the drain should have an adjustable threaded leg with a small nut to secure the setting after you have adjusted its lenght to open and close the drain. Make sure you adjust the lenght to the highest setting for better drainage. The linkage must be connected and tight between the vertical lift rod and the horizontal rod that enters the drain to make the stopper move up and down.
Dec 19, 2008 | Plumbing
Moen 103459 Drain Pop-UP Plug Logo
710 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
