Question about Husqvarna Chain Saw 20" Bar
Husqvarna 357 XP Hard starting when warm.
Husqvarna 357 XP Hard starting. Runs OK when cutting. If allowed to go to idle, the RPM's go up then stalls. Runs fine on fast idle. Seems to be starving for fuel, but the lines are clear and filter is good. Only on its second season of use. Has been trouble free up to this point.
  • msaxtell Apr 06, 2009
    Saw will run then gains a fast idle chain starts to rotate, you hit the throttle and it bogs out.
    Please help.
    msaxtell@msn.com
    Problem Solver:
  • 11 Answers
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Posted on Mar 15, 2009
I'm in the 357XP problem club! Have so far spent
Posted on Aug 24, 2010
Have had same problems with our 357xp's and solved them by replacing the crank shaft seal(Sprocket side) this has so far solved all problems and have now reinstated another 3 scrapped saws.
Posted on Jan 25, 2010
I have had the same problem with two 357xp that i am running. One is about 4 years old and started playing up after about two years, it was sent into a workshop who spent a lot of time looking at before changing the carburetter. It seems ok now but still has to be set to a fast idle. My other 357xp is less than a year old and has now started playing up. I have been told that there has been a number of reported cases with the manufacturer not saying anything. By coincidence i have also been told that the UK Forestry Commission now uses the new 346xp instead of the 357xp.
Posted on Jun 19, 2009
F150 stalls
I'm assuming the truck runs ok once it is warmed up. Sounds like you need to make some adjustments. The cold idle speed is set too high, and the choke is opening too fast. The cold idle should be around 1500 rpm and the choke should take at least 90 seconds to open depending on air temp.
Jun 08, 2013 | Cars & Trucks
Engine runs in idle +/- 2500 rpm
Without checking your car physically, its not possible to give you any idea what it could be or not
Dec 10, 2017 | 1999 Peugeot 206
I have a 2008 mercury Milan with nearly 60k miles on it. When I come to a stop the rpm drops by 1000 then recovers quickly. What should I do to fix the problem? Any suggestions will be greatly appreciated.
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode? http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces? http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
--------How to adjust rpm on 2009 dodge charger SRT8?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increases http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000? http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills? http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPM http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM? http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Driving on the road the RPM goes higher wituout speedind
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode?http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces?http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | 2008 Toyota Avalon
Engine Runs Rough at Idle
go to auto zone,its free ck.throtle senser
Feb 19, 2012 | 2002 Ford Explorer
2006 kawasaki 750 vulcan will not idle , will idle with choke
ok buddy on the carb will be some sort of screw and idle screw turn this in 1/4 of a turn with the machine running until it idles at 1000rpm also the choke will stall the engine when warm the choke is only for cold starts get back to me more info or problems f4d68ca.jpg
Sep 24, 2009 | 1992 kawasaki VN 750 Vulcan
4 cyl Engine starts and idles ok...give it throttle and it dies
I need to get a clear mental picture of what exactly is happening.
With this said, you stated that the car "runs fine" until warmed up.
Q: When you start the car when cold it idles fine?
Q: If you allow the car to idle until "fully" warmed does the car stall?
Q: As the car begins to warm up, Does the RPM fluctuate abnormally?
Q: Does the car Only stall when you press on the gas pedal or does it stall just sitting and idling in addition to pressing the gas pedal?
Q: If you can drive it while cold does the car stall during acceleration when warm or only at Stop Signs / Lights?
Q: If you wait 20min or so, can you start the car again?
Q: How many miles are on the car?
Mar 27, 2009 | 1995 Toyota Camry
2000 durango 5.2 cold starts, engine stalls or rpm surging
i know this may sound stupid but if your battery is old or a little weak on this vehicle the idle air control solenoid will act speradicley hunting for were it should be and the vehicle will stall.replace battery
Jan 31, 2009 | 2000 Dodge Durango
Stalling runs ok then cuts out
sounds like the timeing belt is bad.
Jan 09, 2009 | 1996 Saab 900
1990 Ford Probe 2.2 automatic stalls in forward, reverse OK
Sounds like a bad IAC (idle air control valve/sensor) that controls your idle when going from throttle to idle. If bad your idle will act crazy and can cause stalls easily. Pretty sure that's it.
Dec 20, 2008 | 1993 Ford Probe
Husqvarna Chain Saw 20" Bar Logo
2,542 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
