Question about Logitech Z-2300 Computer Speakers
Need to open my logitech z 2300
Something has gone into the sub and i am trying to open it without breaking the amp
  • Anonymous Apr 08, 2009
    ollolololo
  • manojdomyan Apr 19, 2009
    my mp3 also got stuck inside and i am not able to open it.....
On the back of the subwoofer remove all outside screws running the parameter of the metal back. You should do this with the speaker pointing down so the screws face upward. Once you've removed all the outside screws lay the speaker back in it's normal position and grap hold of the heatsink fins and give a slight twist to it to break the seal. That will loosen it from the back, and you can pull it out about 3 inches. Note: wires are still attached but that should give you enough access to get inside.
Posted on Apr 15, 2009
  • ripcord9 Apr 15, 2009
    If necessary you can, clip the plastic tie wraps holding down the wires to gain more room inside. Be very careful not to clip any of the wires! Also, be sure to get replacement tie wraps to tie back the wires as they were originally. BTW, I have a typo in my first post above. It should read grab, not grap.
  • John Tripp
    John Tripp Apr 02, 2011
    The only way to contact me is by clicking on the Sea Breeze blue color name next to my logo or photo or at end of solution. Then at top of page click the word appl...@yahoo.com Sorry i just don't get comments from others on a different post here on Fixya.....Sea Breeze http://appliance911seabreeze.com/index.h...
Hi, My friend left me his Z-2300 sub but lost the speakers that go along with the system. What speakers are the best replacement for the sub? which dont involve me soldering any wires!
I don't know which would be best but my recommendation to you is go shop around on the internet or in stores and find some good quality 2.0 (2 speakers without a subwoofer) computer speakers. If the speakers don't already have RCA connections it is easy to find a 3.5mm to RCA cable connector. Let me know if you want me to clarify that....audio lingo is very confusing sometimes!
Nov 01, 2010 | Logitech Z-2300 Computer Speakers
Logitech z-2300 subwoofer not working
ahh logitech always the sub that goes. its buggered but dont toss out the whole speaker set just buy another one and youl have spare speakers when you need them
Jul 28, 2010 | Logitech Z-2300 Computer Speakers
I have my logitech z-2300 2.1 speakers hooked up to my imac but the sub doesn't hit near as hard as it did on my pc. have i hooked it up wrong?
Switching from pc to mac could have something to do with that. What i mean by that is the audio card inside the computer is most likely different. It could also have something to do with the equalizer settings on what ever program you are using. If it is a program with an EQ or equalizer setting try turning up 32, 64 and 125 on the EQ. hope this helps
Mar 07, 2010 | Logitech Z-2300 2.1 Computer Speaker...
My dog ate the cord for the volume control. How can I buy a new one?
type in Logitech Z-2300 speakers volume cord that may help or check from where you bought them
Jan 29, 2010 | Logitech Z-2300 Computer Speakers
One channel has no sound
One channel of the amplifier is burned out/damage. It is usually a package IC amp. Live with it or take it get repaired because the IC is hard to order. If you want to do it yourself, open the sub (big box and look for an ic attached to an aluminum heatsink. Look up the part number on the internet and see if you get any hits.
Apr 29, 2009 | Logitech Z-2300 Computer Speakers
Very Quiet Subwoofer - amplifyer problem?
Yes, it is fixeable, but you can carefully check this,
1) open the SUB, and see if any cable is broke or loose in the negative and positive poles.
2) check if there a loose cable on the terminals point of attach speakers.
3) other than this is a defective AMP inside and mus be change.
open sky
Mar 13, 2009 | Logitech Z-2300 Computer Speakers
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Jan 10, 2009 | Logitech Z-2300 Computer Speakers
Z-2300 remote does not work
Fist plug it into something other then your computer like a walkman or mp3 player, cd player etc. If it does work then it is the original device (computer I am guessing) If it doesn't work it is the speakers. These models have lost of problems and this appears to be one of them. Some have a sub button on the back of the speaker with turns the sub off seperately.
Oct 30, 2008 | Logitech Z-2300 Computer Speakers
Sound controller Logitech Z-2300 problem
I would like to know this as well. The cord broke on my controller so now I cannot even use my speakers at all without the cord.
Mar 13, 2008 | Audio Players & Recorders
Logitech Z-2300 Computer Speakers Logo
2,661 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
