Question about Farberware T490C 1500 Watts Toaster Oven with Convection Cooking
Model 460/5 can not control the heat
I set the temperature at 350, but the heat keeps going up . does this have a thermocouple that needs to be replaced?
  • 408 Answers
I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
Posted on Mar 04, 2009
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Cannot control the temperature. Even when I put on the lowest heat setting the coils re bright red. What part do I need to fix it. The model is 31197S Series A2940BR
HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The thermo on all these units is inaccurate anyway as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Jun 15, 2011 | Hamilton Beach 31197 120 Watts Toaster...
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Convection Oven blows fuse. Replaced element. Still blows fuse.
could be anything
get in an electrician to trace the fault
Nov 03, 2017 | Toaster Ovens
Oven does not cook at temperature set at. 2 hrs.
Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Need Part for Farberware Turbo Convection Oven Model 460
hello....i am getting ready to list an unused set of these trays on ebay......they are new in their box....if you need a picture i can send you one.......i'm 20089a1.jpglooking for about 35.00 for the complete set of 3 in their box.....keith
Oct 27, 2009 | Farberware Toaster Ovens
I have a new GE Covection Toaster Oven model 169127/169140. My question is should this oven's heating elements shut off periodically when the set temperature has been reached?
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 01, 2009 | GE 168947 Toaster Oven with Convection...
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
Farberware 460 turbo oven
R
I have the same oven plus another one. Does this model have a "ding" when the timer is finished. My other one does. I bought them both used. Love em for their size. I use them out in the garage during the summer. Keeps the heat out there
Thank you
Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Farberware T490C 1500 Watts Toaster Oven with Convection Cooking Logo
392 people viewed this question
Top Farberware Toaster Ovens Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Farberware Toaster Oven Expert? Answer questions, earn points and help others
