Question about Akai LCT3201AD 32 in. LCD Television
Flashing screen i have a scott LCT37SHA . I hook it all up and it will flash no signal in the upper corner. If i hold in the source button on the side i get good picture. If i let it go i loose picture. i also dont have a remote. HELP
    President:
  • Akai Master
  • 1,779 Answers
You didn't say if it's new out of the box, anyway, check to see if any of the buttons feel abnormal when you press them, they should all feel by press identical. It's possible just a stuck button.
Let me know!
Posted on Mar 04, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Tip
Scott LCT37SHA Manual Download Have you lost your Users Manual / Owner's Guide...
Have you lost your Users Manual / Owner's Guide for your Scott LCT37SHA?
Would you like a digital copy of the Owners Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Scott LCT37SHA users guide.
I hope that helps.
on Apr 19, 2010 | Scott LCT37SHA TV
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
Where can i get a replacement lcd screen for a scott lct37sha? Prefer used. I have tried ebay, craigs list, the manufacturer. no luck
From the exact places you have tried otherwise the new part, directly from the manufacturer - Sharp, will be more expensive than a new tv.
Jul 03, 2010 | Scott LCT37SHA TV
My Scott LCT37SHA TV will not turn on. I am
IF THE TV NO TURN ON THE FRONT LED IN RED CHANGE ALL 470 MF& 1000MF CAP IN POWER SUPPLY, FUSE AND VARISTOR DOWN THE BOARD. IF THE FRONT LED TURN ON IN RED ONLY CHANGE THE CAPACITORS.
Apr 04, 2010 | Scott LCT37SHA TV
Red Light Indicator Flashing??
There is an old message stuck in memory. Hold down the OFF button on the base handset for 10 seconds.
Dec 02, 2009 | Uniden DECT 6.0 Cordless Phone ID
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Nov 16, 2008 | Pioneer DEH-1600 CD Player
Help flash Nixon coolpix L11
hello,
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Akai LCT3201AD 32 in. LCD Television Logo
87 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
