Our irrigation system won't start watering g after we replaced a leaking pipe on our pump
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
SOURCE: Pump will not come up to pressure and turn off!
With no leaks in line and assuming the jet is not embedded in debris at bottom of well, try priming the pump again and getting all the air out.
SOURCE: jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
SOURCE: I need to replace the front & rear bearing on
You can go ahead and disassemble your Davey pump.
You can take the bearing off. On it, at the side, you will
find the bearing number (could be 6001, 6002, 6201, etc.) etched. You can buy the replacement bearing from
hardwares near you.
SOURCE: no water supply to house
i have a hs50-05t with a torrium controller it only works when you hold the prime button in
