Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Usb ports not working for xp any help? - Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
  • David Shaub May 11, 2010
    It's in your computer setup, not XP.
  • 5 Answers
Right click on 'My Computer' and select 'Manage'
Once there, find the Device Manager. If there are any items listed with a ? or ! symbol, click on them and hit the 'delete' key..
Once they're all gone, point your mouse at the topmost entry and right click. When 'Scan for new hardware' appears, click that for Windows to try to reinstall all newly found hardware (hopefully this will include your USB ports and default hub).
If you're prompted to connect to Windows Update, say yes
I hope this helps!
Posted on Mar 04, 2009
Printer only works on one USB port
You can swap thye ports areound on Vista, but Xp is more difficult. What happens is the USB is converted to an LPT port like lpt1 or 2. This remains in the device manager list because it is usally a fairly permanent object. USB printers are rarely totally USB, like other items. So windows fails to recognise the printer on other ports or, it will require a new installation for that port. With Vista you can go into Device manager and reassign a USB port to a printer port. XP is another ball game you might not want to play in.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 18, 2009 | HP Deskjet 5740 InkJet Printer
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
Usb ports (HP Pavilion dv2000 Laptop) unable to retreive data
NO OS STATE is this the XP virus maget , dead for 3 years now?
XP does not work on many USB devices even after the SP3 update
and THE SP3 UPDATE is mandatory. service pack 3
DV2000
id bet you if you booted to linux CD, (knoppix 7 live)
all usb ports work, telling you what, in seconds, XP IS DEAD.
for a fact.
google XP USB dead, (billions of hits for 16 long years)
MS dont support this OS nor VISTA or older.
HP does not support DV200o now its legacy hardware now.
MS plug and play is dead too on XP. per there warnings.
The means all new XP things will be dead, if the maker of said things
does not give you Their soft or that thing..
if hell bent on using XP ,(why) upgrade to W7
then get SP3 there.
https://www.microsoft.com/en-us/download/details.aspx?id=55245
it came new with XP
and was VISTA READY, best is to go W7. !
Goodwill store has $20 laptops with W7 on it working now.
why wait, dump yours, and UPGRADE HW/SW all at once
and WIN.
why to not RUN XP (endless bad and advancing....)
http://www.pcdied.com/XP-sux-sg.html
Aug 02, 2017 | HP GbE2c Layer2/3 Ethernet Blade Switch...
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
USB Ports
one way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Jan 20, 2008 | Gateway GT5432 Refurbished AMD Desktop...
USB port is not working under windows xp sp 2
hi,
you can try the following steps.
Install the driver for the camera and the ipod as XP is preloaded with drivers for cameras for only selected models only.
Hope it helps.
Regards.
bzoy
Dec 30, 2007 | Soltek SL-915G Pro-FGR Motherboard
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
