Question about Kenmore 44102 Front Load Washer
Kenmore 44024 is leaking water apparently from the tumbler not any of the water sources or drains.
  • 188 Answers
Open the lower kick panel and inspect for the source of the leak. If you feel water or see rusty or soapy residue around the tub bolts that hold the tub halves together, remove the cabinet top and tighten all the bolts around the tub. The bolts should be snug when tightening. If the bolts are ok, feel all around the outside of the tub for holes or cracks.
Posted on Mar 04, 2009
Not hooked to water but water leaks from under the unit What to do?
There is a drain hose that empties the defrost water from the cooling coil and drains into a pan located at the bottom of your unit, where it evaporates. Check to see if this drain hose has popped out of this pan, or possibly the pan is cracked.
Sep 19, 2014 | Kenmore Refrigerators
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water coming out from the bottom of washing machine
Have the unit panel taken of to see where the source of the water comes from. It could come from a leak or the water overflows or is not draining. Check for leaks in the valves or hose, as you inspect where the water comes from. To check if it is not draining see after wash if the water drains while the panel is taken off. IT could be caused by the water level sensor (usually a floating device on the tray) may have been dislocated or needs replacement or a faulty water pump.
Sep 12, 2009 | Kenmore Washing Machines
Leak!
Hi as well,
With no other source of water for the leak, this has to be your defrost water, and it does sound like the drain to the evaporator pan is clogged.
The pan will be underneath the unit -- should be a panel you can remove along the bottom edge to access the pan.
If you trace the drain from the bottom of the unit back into the fridge, you can find where the water is supposed to drain into the pan. This is apparently clogged.
May 29, 2009 | Zanussi ZEBF250W Bottom Freezer...
Water collects in tumbler when I am not using the machine
Replace fill vale. Fill valve is leaking water into washer. Fill valve is not closing all the way.
Mar 08, 2009 | Kenmore 44102 Front Load Washer
Water leaking into washer
is the drain plumbed into a spigot on the sink trap? if so this may be the source of water coming in when appliance not in use.
take the drain hose as high as possible in a swan neck under the sink and see if this cures it.
other possibility is a leaking inlet water valve but would expect fault then not to be intermittant
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
Water leak on occasion front load washer purchased around 2002/03
You need to remove the kick panel (under the front door). There are two screws at the very bottom of the kick panel, one in each corner.
This will give you visibility to see where the leak is coming from.
On the right hand side is the drain pump. The black hose goes from the pump,out the rear and into your drain pipe. It is secured by a clamp and is one possible source of leak.
If that connection is dry, look underneath the tub where the two parts, front and back of drum, come together. there is an o ring sealing the two sections and this is another source of water leak. (major problem is this is leaking)
Failing this you will just have to trace the source of the leak. You may have to take off the top of the washer to check the water inlet hoses which run on the top of the machine but would still show as a leak under the machine. Good luck.
Jun 11, 2008 | Kenmore 43042 Front Load Washer
Kenmore Top Mount Refrigerator - leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing
It freezes up for a few reasons. First the water is not running down fast enough. That is why the wire was added to add heat from the heater to the drain hole. The metal pan under the evaporator coil may not be lined up with the drain hole well enough and holding water there. If that looks ok the drain tube that runs down the inside back of the unit might be slightly restricted. Not much you can do about that. I would make sure that the aluminum wire goes in the hole about 2 inches and that the unit is tilted slightly back to help water flow.
Apr 18, 2008 | Refrigerators
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Kenmore 44102 Front Load Washer Logo
87 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
