Question about Samsung L100 Digital Camera
Card error on L100 samsung camera, help please.
I have the the samsung L100 camera, and i've had it for a couple months. I have a kodak 2GB memory card in the camera, and i was taking pictures a few hours ago. Then when i turned on my camera "card error!" had popped up. any help?
  • 1 more comment
  • naypig Mar 19, 2009
    i got a new battery for my l100 and since then every time i've turned it one, card error has appeared and it will not let me take pictures.
  • Anonymous May 10, 2009
    i put my 2gb kodak memory card into my pc to import my pictures and when i turned on my camera it said my memory card was locked..now i cant take pictures
  • Rob
    Rob May 11, 2010
    When did the card error happen? Was it right after you had the disk out and in a pc?
    Or were you taking pictures, turned the camera off, then when you turned it back on, it gave you the error?
    Let me know.
    Rob
  • 56 Answers
Copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
Posted on Jul 02, 2009
  • chris garcia Jul 03, 2009
    copy all your files from the memory card to your computer, then FORMAT your memory card in your camera, go to MENU> SET UP > FORMAT
    make sure that you have a copy of all your files in the memory card because FORMATTING the card will erase all the files in your card
    hope this helps
  • minniecedes Aug 06, 2011
    Even with the format, it still shows the error!
Memory card is protected. Reset switch on memory card.
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position (but you've checked that already). The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Please note that the C633 is an older camera, and can only use 2GB or less standard SD cards. 4GB or higher SDHC will not work with your camera. Fortunately 2GB cards are relatively inexpensive these days, and may be easily found on Amazon if your local store no longer carries them.
Oct 28, 2011 | Kodak EasyShare C633 Digital Camera
My c703 won't format a new memory card. The old memory card is full (2GB), but I've tried two NEW Lexar 4GB cards and neither will format. Help!
Hi, The reason neither 4GB card will format is because that camera is only able to support, at most, a 2GB card. I'd suggest returning the 4GB card and getting another 2GB one.
May 13, 2011 | Kodak EasyShare C703 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
My memory card is locked how can i unlock it??
SD and SDHC cards have a slide switch along one edge. The position furthest from the contacts lock the card, the position nearest the contacts unlocks it. Try sliding the switch fully away from the contacts, then fully toward the contacts. If that doesn't solve it, try a different card.
Jan 24, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
Jun 03, 2009 | Kodak EasyShare C330 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
File errors, distorted photos.. I hate the Samsung L100!!
regarding the use, you have to check if you are using the right memory card for your camera.
you can only use 2GB sd card or 4gb sdhc card.
try this and if you still have an error message. you better send the camera for service.
Jan 19, 2009 | Samsung L100 Digital Camera
FILESYS ERROR E00100
Which size has the card?
Is the write protection enabled?
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Dec 20, 2008 | Kodak EasyShare C330 Digital Camera
Hello i have the kodak easyshare c330 digital camera . i just purchase a kodak sd 2gb memory card the camera is stateing that the memory card is full can you help me with this problem please
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
Samsung L100 Digital Camera Logo
417 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
