Question about Panasonic NN-S963BF Microwave Oven
Panasonic microwave nn-s963bf making grinding noise
Our panasonic microwave nn-s963bf (manuf. May 2003) is now making some loud grinding/grating noises when running. It almost sounds like a bearing is gone on the turntable, but am not sure. It sometimes continues for a second or two after the cooking stops. Any ideas if this is a serious (i.e. replace it) problem or something minor that is fixable (hopefully by me)?
  • candaz04_007 Mar 07, 2009
    Checked out the turntable rotation by manually turning it as per the helpful info from MicrowaveSvc and it sounds fine.
    Didn't know we could set it to be off via the control panel!
    That seems to rule out the turntable system, so not sure what else it could be?
  • candaz04_007 Mar 11, 2009
    Looks like after I spun the motor manually last time, that the problem seems to be resolved! For now, looks like we're good to go. Thanks again for the helpful tips. Cheers!
  • Panasonic Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Mar 06, 2009
  • William Miller
    William Miller Mar 10, 2009
    If it sounds like it;s coming from the bottom of the cooking cavity, it may be one of the wheels on the turntable support grinding.
    It may be worn and need a little drop of cooking oil on it where it connects to the support.
    Does it do it when you run the oven empty for just a few seconds?
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
Starts and runs for 5 seconds and clicks off and shows no time on timer, back to ready mode, not the normal "enjoy your meal".
Starts and runs for 5 seconds and clicks off and Problem with the Panasonic NN-S963BF / NN-S963WF 1350 Watts Microwave Oven
Jan 31, 2011 | Panasonic NN-S963BF Microwave Oven
How to change bulb
many microwaves have a small panel on the side. Undo the screws to get at the bulb.
Nov 28, 2010 | Panasonic NN-S963BF Microwave Oven
Where is the second fuse in my panasonic nn-s963bf the one for the heating and what does it look like?
There is no second fuse. Look for a thermal cutoff there are a few of those. Test it for open circuit and replace.
Aug 11, 2010 | Panasonic NN-S963BF Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
Sparking behind the wave guide in model NN-T664
The antenna on the magnetron is wearing out becuase it is damaged. Replacing the antenna from another magnetron normally solves his problem.
May 13, 2009 | Panasonic NN-T655SF Microwave Oven
Panasonic Microwave NN-C980-B buzzing noise but it still works.
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Fan on left makes awful noise as if grating or knocking
Remove fan and check for loose debris or screw that is hitting the fan.
Dec 13, 2017 | Panasonic NN-H275 Microwave Oven
Panasonic NN-S963BF Microwave Oven Logo
1,510 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
