Computers & Internet Logo
Posted on Mar 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I expanded my email screen and cant size it to the screen so i have lost email functions
I brushed my mouse in such a way that i expanded my mail.com email site and now i cant check my mail. its the only time i ve done it. any ideas
castletech
Level 3:
  • Master 372 Answers
  • Posted on Mar 31, 2013
castletech
Master
Level 3:
Answers
372
Questions
0
Helped
102724
Points
1338
Have you tried double clicking the title bar at the top of the window.
Pressing the F11 key to turn off full screen mode
Closing the window by double clicking the top left corner or by pressing the Alt F4 keys.
Hope that helps
Charles
1helpful
HOW DO I FIX LOST MAILS TOTALLY AFTER USING REPAIR TOOL?
It seems that the dbx file size is reduced either because: 1. The repair tool modify and reduce its size, remove the emails. or 2. The last time when you restart Outlook Express, it reduce the dbx file size and remove the emails. If you still have the original large dbx file, then you can recover all the emails inside it with OE-Mail Recovery at http://www.oemailrecovery.com/inbox-repair.html
This tool will never modify the original dbx file, instead, it will output the recovered emails into an output folder so that you can either open or import it back to Outlook Express. If you do not have the original large dbx file, then it is still possible to recover your emails. As long as you have stored the .dbx file on your local disk or drive, the email data may still exist on your disk/drive. You can you can search Google utility to scan the whole disk/drive and recover the emails for you.
How do i reset my email fonts
Changing font size for reading in Outlook and Gmail
To read Mail in a larger font in Outlook:
  • Hold down Ctrl while turning the scroll wheel on your mouse down.
In Outlook 2007 and later, alternatively
  • Open the message in its own window.
  • Click Other Actions.
  • Select Zoom... from the menu.
  • Choose the desired zoom level.
  • Click OK.
Outlook will not remember the zoom level.
Since this does not work with plain text emails (the mouse wheel does), also select Tools ' Options... from the menu, go to the Mail Format tab, click Fonts... and use the Choose Font... button under When composing and reading plain text: to choose a bigger font. The above instructions are courtesy of About.com.
Here is a link referring to reading Gmail.
https://readingonscreen.wordpress.com/text-adjustments/gmail-text-size/
Increase text sixe of e mail
The displayed text (font) size for a web-site or page is a function of your browser. Try these to icrease or decrease the text size on your email:
Zoom in - <Ctrl><plus>
Zoom out - <Ctrl><minus>
Reset zoom - <Ctrl><zero>
Adjust zoom - <Ctrl><Mouse Wheel>
Firefox - View -> Zoom -> Reset
IE - View -> Text Size -> Medium (or other sizes)
Safari - View -> Actual Size
Chrome - Current Page Settings(Icon) -> Zoom -> Normal
How do I change font size of my e-mails
Email Tool Bar
Spell Check - Text Size - Fonts - Colors
Emoticons - Bold - Underline - Etc
(These Options Can Not Be Saved As Defaults)
(They Must Be Set Up Every Time You Email Some One)
Set Up The Tool Bar
Settings For The All New Email
if the tool bar is not enabled click rich text beside the subject line
( When you start composing an email you can hold your mouse over the little icons you see above the message you are typing
they will tell you what they do )
spell check which is abc is above From above the message
for fonts use the first drop down box above your message to choose one
for text size use the second drop down box
Settings For Classic Email
click options on the right top side of the mail page
then general preferences
scroll down to composing e-mails section
check the box - compose messages as color and graphics
Text Size Adjustments For Any Webpage
go to top of this page in the grey area
click view
then text size
adjust size
Font Size And Screen Width For Your Yahoo Message"s
Steps For The All New Mail
click options on top right side of mail page
then mail options
then contact options
click mail on the left side
then font size
screen width can be changed there also
remember to click save
Steps For Classic Mail
general preferences
then font size
2answers
E mail page is very small unable to read due to minute size
You can use the zoom function in browser to increase text size. Press Ctrl (keep it pressed) and tap + key to increase font to your desired size. To reduce size tap - (minus)key and to restore to default size press "Ctrl and 0" together.
May 18, 2011 • Yahoo Mail
This has happened several times... so hopefully you can teach me what I am doing. I am in the middle of writing an email, my hand moves.... somewhere.... and the message is deleted. Sometimes it goes to...
What e-mail program are you using?
Try placing a piece of card or a thin book or similar item over the touch pad so it cannot be touched. Then try typing an e-mail. If the problem goes away then it is definately a problem with the touch pad. If the problem remains then there is some other problem, possibly the keyboard layout cause you to press the DELETE button by mistake.
If the touch pad is the problem then try setting the touch pad sensitivity to minimum. Plugging in a USB mouse DOES NOT disable the touch pad, so this will not help you if you accidentally brush the touch pad while typing.
1helpful
The screen window becomes so small that even the messages cant be read...pls help
Change the Display resolution of the Monitor. Also, press the Ctrl Key and roll the Mouse key to increase the Font size.. Get back to me if there are any issues so that I can assist you,,
Jul 10, 2010 • Yahoo Mail
How do I get a full screen when opening yahoo mail? My font size is reduced and panels show up on both sides of screen.
If you are using a scrolling mouse :
follow the steps below:
1. hold the ctrl button and scroll the mouse downwards and release
scroll according to your font size you use.
ok
Nov 12, 2009 • Yahoo Mail
14helpful
2answers
I can't see my yahoo mail in full-screen view. The email is small on the screen.
Press and hold ctrl on your keyboard and then scroll the mouse wheel while in yahoo mail, this will zoom it in more or out.
Oct 12, 2009 • Yahoo Mail
1helpful
3answers
Size of font on incoming e-mail
Font size can be increase by hit the Ctrl++ key.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
